Tire jack replacement suggestions
lostranger2026
Forum Member
Cortez
CO - USA
Vehicle
Drive
The little spiral jack that came with my '99 ranger broke. Good thing it happened when I was practicing while changing the spare tire and the car was completely supported with stands etc.
Either way, I was not impressed by the emergency jack supplied by Ford, hence I'm looking for suggestions on something that would fit in the original compartment behind the passenger seat and would be a good replacement.
My bed is open and I got a 2 seater, so very little cab space up front.
Is a bottle jack a good idea? I like them, but I had oil failures on them before and this is a roadside emergency thing, so reliability is key.
Thought about a scissor jack, but not sure what kind of lift I need for a regular non-lifted ranger with stock 14" tires.
Could always check the salvage yard for another telescoping jack, but would like to hear other people's opinions first. Right now I'm lugging a 20 ton house jack around, which is total overkill but all I have.
I have used & abused the factory jacks with no problems.
because the rod hooks into them they can be moved around and held in place from the other end of the rod.
they usually don't flip over like scissors can at the bottom.
yep, they take forever to crank up.
id probably just get one at a junkyard
This. Or, ask in parts wanted, surely somebody has one they'd send you for just postage. I don't have one, sorry.
I actually keep a factory jack with my junkyard tools.
I’ve used bottle jacks for years. I just carry a couple pieces of wood blocking to set them on. Floor jacks are more stable if you have a relatively solid surface but they take up space. The new “off-road” jacks look really nice for use outdoors, but again, space. Usually what lives in the truck is a factory jack or a bottle jack. I use bottle and floor jacks at home, mostly a floor jack though. Space is less of a concern at home.
Full size trucks and vans often have bigger/heavier crank up bottle jacks, look for those at the junkyard too.
Thank you all for the ideas. I'm gonna see what I can find at the junk/salvage yard!
Even if you just go with another factory jack, I would recommend you find a scrap piece of plywood to use as a base to set the jack on. Murphy's Law says when you need it, you will be on a soft shoulder with poor support for the jack. I have a piece that is roughly twice the size of the jack base to spread out the load to prevent the jack from sinking into the dirt and to minimize the likelyhood of it tipping. 1/2" thick plywood works but 3/4" is better.
Agreed. Always carry cribbing. I carry a couple square pieces of 2x10 and a few chunks of 4x4 around 12-16 inches long.
I was reading recently that older Japanese jacks are very well made and not hydraulic. They would probably of the right size to fit a ranger.
Absolutely agree. I carry a piece of that around with me at all times. I once had to use a half scissor jack (VW!) to change a tire and the bloody thing started sliding away from me in the berm when I just got the tire off. Thank god I had two friends close by, so while they were trying to push the car "back" I was scrambling to get the flat back on with just two bolts before it collapsed. Half scissor jacks are absolute deathtraps if they're not perfectly vertical.
