Ultra cheap offroad race Explorer turned rock crawler
I wire wheeled as much as I could yesterday and am calling it good. Not going to paint anything. Also finished up the engine crossmember. I just used a couple pieces of flat strap on the back side. I might revisit that in the future if & when I have the engine out and more room to see what I'm welding.
Axle is back under the truck and I am waiting on an email from AccuTune to tell me what springs I need. I have a long list of little things to work on this week. I really want to work on the front bumper and get the winch mounted.
Still waiting on spring info so I figured I'd work on a winch mount. The original plan was to use a Warn 8274 that I've had for years. I mocked up a quick mount and decided that it just sticks out too far, looks stupid, and is going to kill my approach angle.
Soooo I shifted gears a bit and took the winch off my car trailer. It is maybe a bit more ideal because the solenoid pack can be removed and relocated - makes them really compact. I was able to tuck it under the grill just a bit and that shortened up the nose of the truck by 6".
My original plan was to do my typical style C channel bumper but I got a bit ahead of myself and didn't plan that very well. I have done a bunch of those anyway, time for a change - the new plan is still formulating in my head but I'll just hint that it involves the tubing bender.
A bit done this afternoon. I am going to brace the back side of the wings and fill them in and the top.
AccuTune told me that the springs I have will be fine and that I just need to adjust the preload down further. Did that and am more happier with the ride height.
Not much picture worthy to share quite yet, I spent most of last night doing little things like putting the calipers on, lock nuts on everything, etc. I needed ride height to be where it needs to be so I could measure for a front brake hose which is now on order. Tonight I am hoping to have the winch mount 100% done and hopefully the bumper as well or at least pretty close.
Hey dumbass, quit having your buddies over for beers on a Wednesday and you'll get more done.
I found a mounting location for the winch control box that should work great. I made longer wires out of some old janky battery cables and verified that the winch works properly after this. I am going to run part of an extension cord into the cab for a switch and that will be tapped into the control box here. That way I have winch control without having to dig out the controller, or I can still plug a controller in, or I can use the wireless controller.
