2.3L ('83-'97) Stumbles and dies on cold start and after sitting.
Featured Build Threads
Same conditions but yes it is a different gauge. I was skeptical of the other one from the start (I was renting from autozone) so after that test I went and got my own and it’s reading better now.
Still dropping off to 0 basically instantly?
The immediate drop off was probably the check valve at the outlet of the old pump, why I don't worry about that too much... oddly enough probably what the startup problem with my '97 is, just don't want to pull the bed yet while the pump is working fine otherwise...
Just to simplify things with all that you've done, what are the symptoms that are left? I know you've gotten rid of a couple, it gets confusing with the parts changed and such...
To put it simply, none of the parts changed so far have made the starting any better. Really no noticeable change from the original symptom other than my gas mileage has gotten better since replacing the fuel pump but still very rough on cold starts, easy fire up but struggles and shakes to catch it self on the idle down from fire up.
Sorry for the delay all, got notified the FPR was delayed in shipping and won’t be here this weekend so standby for the update on the running issues after that is replaced.
I also wanted to add a detail from when I replaced my fuel pump I didn’t note when I first posted. The mpg has been a lot better since replacing but still not to par with what it was before the issue. My fuel filler neck is cracked around the hose connector to the fuel tank. I have noticed it leaks a bit of fuel if I overfill the tank for a year+ now and finally saw the damage when I pulled the bed off but I don’t think this would be causing my issue so I just wanted to mention it in case it is an issue or if anyone knows about that. Appreciate the help and patience!
My filler neck has the same issue, oddly enough I wrapped it with a generous amount of "pipe wrap tape" (basically wide electrical tape) and well that was like 4 years ago and it hasn't leaked gas when filling up since... always ran fine.
Dumb thought is the purge solenoid, don't remember if that's been mentioned before, they can cause flooding which is making me question the starting issues I have sometimes... It's free to test, you shouldn't be able to blow through it with your mouth
Update: FPR was replaced and also changed the vacuum hose because it snapped on removal. Truck sat overnight with battery disconnected, also checked the PCV when I was down there and it rattles so I assume it’s working. Got everything reconnected and issue still persists on first 10 attempts to start. Getting good fuel pressure.
Gonna take a step back and just check all my grounds make sure all clean and solid connections but other than that I am confusion!
So I ran another live data test on my drive to and from work.
Symptoms are still the same for cold start, and wants to die out if I don’t hold it steady with some throttle. Still seeing fairly high negative fuel trims on start up but no when I am driving and actively accelerating my fuel trims for both long term and short term normalize to 0% under load but on decel or coming to a stop and idle at a light they both shoot back to the -20% range. O2 sensor data looks like it is switching from high to low more often than previous tests so I assume that those are working just fine but still stumped and just wanted to give an update.
No noticeable fuel or vacuum leaks present and no air passage blockages. IAT and ECT are reading proper values from what I can see but I am going to swap the IAT with a new one since I replaced the ECT just want to rule them all out since it’s cheap. Still need to check all my grounds but other than that I’ve also read the purge valve solenoid could be causing some issues as well as a previous comment here, how exactly do I perform that blow test you mentioned?
dumb thought but it might be worth adjusting the idle stop screw, if you unplug the IAC valve does the engine idle once it's warm? It should idle around 500rpm with it unplugged, if not I would screw out the idle stop screw until it does that, it should help your stalling if it is out of adjustment...
Another parts update. Replaced the Purge valve since I was able to blow through the original and also replaced the IAC since it was cheap and 30 years old. I had the battery disconnected during these swaps and issue still persists. Still not able to hold an idle on cold start and now when I try the clear flooded engine test, the engine will crank and start where it wouldn’t before I replaced the FPR and purge valve. I don’t see any leaks from the FPR but could that be causing the drip down even thought its new? Will report back with some more fuel trim data after a few drive arounds.
And yes when the engine is warm and can hold idle the IAC responds accurately and drops so low idle and doesn’t die and picks right back up when reconnected.
Have you tried running it with the IAC unplugged? On a warm engine you should be able to start the engine with the IAC unplugged and it should idle about 500rpm, if it will not do that, screw in the idle screw until it does hold around 500rpm idle.
I would not worry about the clear flood mode thing, my '97 doesn't pass that test either and it runs fine somehow... sometimes it will fail to start after being at work all day if I let off the starter too fast, I think it floods so probably the purge valve on mine but the idle stability is reasonable until it gets over 90F outside but that's a whole other bag of hammers that I think I have a handle on...
Hey all, just been dealing with the rough starting and revving it up to keep it stable until it’s warm enough to drive normal and figured I’d post some of the live data my scanner was pulling today because it seemed odd to me but could be normal as I am still no expert with these graphs. I will post below and I have three photos, you can see the time stamp of run time at the top if you expand the photo. After running and driving for 6 minutes, the photo is a snap shot after coming to a stop at a light. The next photo is after a little less than a minute of idling at said light and the fuel trims normalize to 0 and O2 sensors ping high. (Just looked off to me when watching it live). And the last photo is me driving down the highway. Hopefully someone can diagnose this data better than I can and help narrow down the problem. I did buy new Bosch O2 sensors but don’t really want to replace until the other issues get clearer. But I also retested the IAC when the engine was warm by unplugging and it sits nicely at ~500rpm and jumps back to ~800rpm after reconnecting.
Upcoming TRS Events
Featured Ranger Based Vehicle
