- Mar 2, 2026
- Long beach
- State - Country
- CA - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
So I have been at this issue for a while now and still no luck. I have a ‘97 2.3L ranger 5-speed manual xlt
I went on a work trip and left my truck sitting perfectly fine and running per usual for two weeks. When I returned it was now firing up just fine, cranked normally and started but then after the high rev it would start to crawl back to idle but never catch itself and just die out. Start after start to no avail. If I give it some gas and save it on the down swing I can hold it steady or flutter it to hold it alive until it gets up to temp and can hold itself at idle again. After it gets warm it will sit at idle just fine and run like normal with no loss in power noticeably, no hiccups, no stalls. After a few days I did some scan testing and tried to troubleshoot. I was getting very negative short term trims and then started shooting all over the place. Got some MAF and o2 codes so I decided to replace the MAF with a walker products one from rock auto and the light has been off now since then but the truck is no better. I decided it was either fuel delivery or air mixture so I started to tackle those parts. I have replaced the IAC, ECT, Fuel pump, fuel filter, spark plugs and wires for fun, cleaned the throttle body and new air filter. It runs the same when I disconnect the MAF. I tested the FPR and it’s working when I pull the vacuum hose off the idle drops a bit and then back to steady when connected and no fuel in the line so haven’t replaced that yet. Looking for other suggestions on what could be the issue, hate revving the truck on cold start and don’t wanna murder the pistons anything too serious.
