2.3L ('83-'97) Stumbles and dies on cold start and after sitting.
Ranger_97
Forum Member
Long beach
CA - USA
Vehicle
Drive
So I have been at this issue for a while now and still no luck. I have a ‘97 2.3L ranger 5-speed manual xlt
I went on a work trip and left my truck sitting perfectly fine and running per usual for two weeks. When I returned it was now firing up just fine, cranked normally and started but then after the high rev it would start to crawl back to idle but never catch itself and just die out. Start after start to no avail. If I give it some gas and save it on the down swing I can hold it steady or flutter it to hold it alive until it gets up to temp and can hold itself at idle again. After it gets warm it will sit at idle just fine and run like normal with no loss in power noticeably, no hiccups, no stalls. After a few days I did some scan testing and tried to troubleshoot. I was getting very negative short term trims and then started shooting all over the place. Got some MAF and o2 codes so I decided to replace the MAF with a walker products one from rock auto and the light has been off now since then but the truck is no better. I decided it was either fuel delivery or air mixture so I started to tackle those parts. I have replaced the IAC, ECT, Fuel pump, fuel filter, spark plugs and wires for fun, cleaned the throttle body and new air filter. It runs the same when I disconnect the MAF. I tested the FPR and it’s working when I pull the vacuum hose off the idle drops a bit and then back to steady when connected and no fuel in the line so haven’t replaced that yet. Looking for other suggestions on what could be the issue, hate revving the truck on cold start and don’t wanna murder the pistons anything too serious.
Sounds like it's starving for fuel at startup.
Have you tried cycling the key a few times before you try to start it?
The o2 sensor is reading rich so I thought it was an air problem at first.
And yes I’ve tried to cycle and prime the system a few times before start and still no better. I tested the fuel pressure before I replaced the pump and I was getting 0psi key on engine off, 30psi on idle, and fast drop to 0psi when engine turned off so I suspected the pump because the regulator tested fine with the pressure gauge, dropped 10psi and shot back up when reconnected.
I don’t own a gauge so I tried to do a test after I replaced the pump at an auto parts store and I was able to start and drive but was still reading 0psi key in engine off and 0psi at idle so I just assumed the gauge was garbage and took off.
Sounds like a massive leak. Injector stuck open maybe? Fuel leaking into the engine could cause no pressure on rail but still run VERY rich. I'd expect the exhaust to be unbearable at that point...
Surprisingly there is no dark smoke from the exhaust and not a very strong fuel smell from the tail pipe either. Going to look into injectors next and see what I can find with those. At least ford made it easy to check the injectors lol…. I wish.
So I test the fuel injectors and they all tested good ohms and volts. Put the truck in clear flooded engine mode while
Both warm and cold and does not fire which is good, means my injectors should not be leaking if I understood that correctly. Still very stuck on this issue and not sure where to go from here. I don’t want to replace my O2 sensors because that wouldn’t affect my idling at cold start since they only read about a certain temp but the only codes I’m getting right now are rich O2 codes. Any suggestions are very much appreciated!
Where were you getting this reading from? Fuel pressure should still be kept even after key off so it sounds like it is very quickly escaping.
From my understanding there should really only be 3 places for the fuel pressure to escape (ignoring external leaks).
- Into an injector that's sticking open.
- Into the tank via the return line to due a failed FPR.
- Back into the tank via the feed. Defective pump or maybe a cracked line inside the tank?
Someone with more experience than me can chime in if I am wrong, but a leaking fuel injector and a leaking FPR could both cause rich running conditions.
Do you have a code scanner that can show the 02 trims & ideally live data (with a graph)?
Knowing what the trims do based on RPMs and load can be a useful indication as to where the problem may be..
Also being able to see the reading can show if the sensor itself is bad or not.
If the sensor reading is pegged at it's highest or lowest value then it's probably a bad sensor or connector, but if it's readings are fluctuating and responding to what the car is doing then I wouldn't even consider replacing it until you sort out the other issues.
You are correct that the sensor itself shouldn't effect the truck's ability to start though, those come into play once it's started and warmed up a little bit.
I was testing at the shader valve on the fuel rail, I was shooting down to zero whenever I turned the engine off but my FPR tested fine at idle when I disconnected it so I went ahead and replaced the fuel pump since the injectors tested fine with the clear flooded engine mode. Replaced the pump and issue still persisted. I am getting good pressure reading all around, holds 30psi key on engine off and holds during idle, holds when engine is shut off and jumps 10 when regulator is disconnected and no fuel smell at the regulator and no dark smoke so this is where I get stuck. What else could be causing this if it’s not a fuel delivery issue?
I have a scanner and the O2 sensor starts high and will swag with rpm input but stays high and drops on rpm drop. The short term fuel trims have been the weirdest through this search as it mostly holds at 0 during idle and drive but will have random spikes between -20 to 14% swings. I will attach the graph below of a short drive with engine at warm temp.
  • Stumbles and dies on cold start and after sitting.
I would be very surprised if this wasn't a fuel delivery issue.
Fuel pressure spec is 35-40 PSI with engine off, so you are actually a little low on that front, assuming the gauge is reasonably accurate.
But more than that the pressure should be held for some time once shut off for, theoretically for quite a long time. As a minimum of sorts the steps I linked to below have a leakage test which indicates fuel pressure should drop no more than 2 PSI over a 3 minute time-frame.
Well in theory a bad regulator can return too much to the fuel tank and not leave enough pressure for the injectors (one of the steps linked actually checks that) . You wouldn't smell it running rich or visually see the smoke since the fuel would be going back into the tank. That doesn't super correlate to the rich code, though. (but fuel pressure does influence how much fuel and how well it burns, so maybe it's reading unburnt fuel from poor atomization, or maybe there's even multiple issues?)
I can't find these same steps for a 97, but here are some good steps for testing the fuel pressure and narrowing down where it's going wrong.
Should be able to ignore the STO stuff (which I do not believe applies at all for a 97), instead key on will run the pump for a few seconds just fine.
The fuel multiplier on my '97 varies about like you mentioned
I don't think I'd dwell on the fuel pressure, that stuff happens...
I'll try to do some thinking about it tonight and see if I can help more...
After some digging the other night, I may have not don’t the best test on my FPR, I was disconnecting the vacuum hose on the intake side since the line coming out of the regulator itself is hard to detach and attach quickly and assumed I would get the same results. I am not sure if I will get something different but I will try doing it at the regulator this weekend and see if that makes a difference. May just end up throwing on a new motorcraft FPR just for the sake of the 30-year old truck and couldn’t hurt. I am also thinking if that fixes the starting issues I will reinstall all of the oem IAC and MAF since they have been cleaned but replaced with aftermarket to try and troubleshoot this issue.
Also curious if I should be replacing the O2 sensor that has been throwing the CEL since it’s been running rich for at least a month now?
Thanks again for all of the help, I will post an update this weekend if the regulator tests any different.
O2 sensors have a shorter lifespan than any other sensor, I had gotten some O2 errors on my '97 at around 200k around 2 years ago and ended up pulling the stock Motorcraft O2 sensor out, no codes since...
I got distracted last night, I'll try to sort out what you have going on now and see if I can help tonight.
I re-tested my pressure today following these steps and everything checked out according to the tests. The only one I can’t manage is disconnecting the return line and checking there but the regulator side of the vacuum hose was dry and no fuel. I was getting 38psi key on engine off and same at idle. The only odd part was when starting the car with the hose disconnected from the FPR is it kinda ran better but still wanted to die at some points but the pressure held steady. After reconnecting the hose pressure dropped about 6psi and engine died.
Hoping this means the regulator is bad because I have a new motorcraft one on the way. Getting P0172, P0135, P0141 still. Decided not to replace O2 sensors since they must be reading accurately if they are giving this code and the car isn’t running right so they will stay for now until FPR is replaced and driven a bit. Will update after installed.
Thank you again for all the advice and guidance!
I re-tested my pressure today foll...nk you again for all the advice and guidance!
Oh that is weird! I can only see your entire message when quoting it. I thought I was missing a bunch!
Crossing my fingers that a new FPR fixes it for you?
btw is this with the same pressure gauge and roughly the same engine conditions? Since the other time you said 30psi
Same conditions but yes it is a different gauge. I was skeptical of the other one from the start (I was renting from autozone) so after that test I went and got my own and it’s reading better now.
