ISO 4.0 TDi swap kit.
Soeedemon157
Carson City
NV - USA
Vehicle
Drive
Before I drop a ton of money on a new kit, just checking to see if anyone has one they’d want to sell. Putting an ALH Tdi in my ‘83 Ranger manual. I have the motor already, just need adapter plates and engine mounts. TIA
  • ISO 4.0 TDi swap kit.
might want to use a toyota transmission.
people that swap out to tdi likely not selling....but i can see someone being intimidated and not using a kit .... worth the ask i wager...
2wd or 4wd application?
2wd...
i would consider a toyota transmission. w56 kits often can reuse stock starters. at the right place u pull yard you can source all of the shaft parts parts and starter under 200 bux.
the 56 and 58 and r series like 154 used to be easy to get cheap but its area dependant now.
there used to be a kit that reused the stock ford starter but i have not seen that in years anywhere.
this style kit for an older 2wd would be something i would do.
with a 4wd and say you were looking to convert also to a straight axle....i would still use the toy powertrain to allow for the marlin crawler stuff and run a gm 10 bolt/d44 or dodge old school 44.
but if you have a 2.8 v6 trans and are happy with your current 4x4 configuration, then going to the normal tdi kit is the deal.
if you have a 4 cylinder 4x4 then you need to get a different bell or maybe go custom....not alot of lima options for tdi.
this 2 in thick setup seems ideal to get clearance and leave the trans right where it is.
2wd...
Thanks for the response Bobby! Yeah, I was hoping finding someone that may have purchased the kit and had a change of plans for whatever reason. I am planning on keeping the 4x4, but do want to upgrade the trans to the MDO5-R2.
I'd be surprised if there is a kit for that. At that point you'd need one to swap the TDI into an F150 or Mustang
likely means r1....but there are kits for Windsor and SBC.
Upcoming TRS Events
Featured Ranger Based Vehicle
