Trying to get replacement wheel studs that are 3 inches long, I can't find any that are the specific knurl diameter of 0.570 but I found ones that have a knurl diameter of 0.563 will these be to small of a knurl to press in will they be loose?
For wheel spacers requiring longer studsAre you planning for wheel spacers that require longer studs?
Or some drag racing rule you need to meet?
At this point I'm thinking I'll have to get the rotors machined for the old moroso studs I have in the other rotors to fit these 3 inch studsAre you planning for wheel spacers that require longer studs?
I've also heard thatAlso somewhere I've heard thread engagement should be the same length as the diameter of the stud
