4.0L OHV Intermittent crank no start. Help!
Lancaster
PA - USA
Vehicle
Drive
I got it back in November and it ran several times with a little trouble, but by mid-December, it would not start on almost all attempts. I’m not very skilled with cars yet, so I’m kind of stuck. I replaced the fuel pump, crankshaft sensor, and spark plugs. I think fuel is good, so I’m not sure what would just fail or work intermittently, or maybe I messed something up. For example, it started today, but when I turned it off, it would not come back on after many attempts. Thanks for any help you can provide.
We need to make sure of our terminology. The engine;
Won't turn over or crank with the starter?
Or the engine cranks and cranks but will not fire off.
Cranks every time, but it seems to randomly work as far as starting, so nine times out of ten it does not start. Thanks
So it will not be the battery or the starter. Do you hear the fuel pump hum every time you go to start the truck, but do not crank it right away? It should hum and then stop.
Franklin’s question is a great starting point. In addition, there is a test you can do. Spray some starting fluid into the intake while trying to start the engine. If it fires and tries to run off the starting fluid, then you know you have a fuel delivery problem. Fo the test several times to be sure. If it does not try to run on the starting fluid, then you have a spark/ignition problem. This is often called the 50/50 test because it eliminates 50% of the troubleshooting headache right away.
