Need help on 94 ranger either short or bad alternator or something else
I agree the 42V thing is probably a red herring, although I would think it should regulate itself down to 14.4 or whatever even with no load.
What we're left with is that something in the system is failing with a very small voltage increase. I think mechrick's suggestions of looking for shorts/intermittent shorts is the right approach. Given his example with injectors earlier in the thread, I'm back to wondering: has anyone seen a coil pack fail this way? Seems plausible though unlikely. However, we're obviously dealing with something strange here.
I should have asked this sooner - do schematics for the computer exist? I feel like I've looked for them before and failed. I'd really like to take a look at the regulation and I/O circuitry.
Edit: can I get someone with good eyes to look at IC13 in the computer photos above? Does it look to anyone else like there's a chunk blown out of it? Should be flat on one side and round on the other. Might be a trick of the light, might just be conformal coating, looks different from picture to picture.
All Injectors ohm at 7.4 ohms
I don't see an evap canister solenoid or wiring for it i disconnected egr valve still won't run tried unplugging tps sensor still won't run and also tried unplugging Grey metal box on passenger firewall still won't run. Could the coil packs have anything to do with problem i know they are old but don't know how old they are
Ohmed both coil packs on connector side of both coil packs i get 0 ohms on wire side of one i get 11.39 ohms and 12.12. on wire side of other coil pack I get 12.96 and 13.02 ohms
Where exactly are you measuring 0 ohms? Between which 2 points?
Middle pin and either side of middle pin on connector/harness side of coil pack
I can't wrap my head around this theory. The vehicle electronics are made to tolerate fairly wide voltage swings. And it runs fine without a charging voltage hooked to it. So everything is working.
Unless maybe one of the 5v regulators inside the computer has failed? While the 5v supply is designed to tolerate wide varying voltage inputs, the output to the sensors has to stay 5v on the money or the sensors will go wacky. I have never heard of this happening before. I guess anything is possible.
I did a quick scan of the old posts. I see where he replaced the ignition module, but I haven't seen where the ECM has been changed. Not a fan of just changing parts, but I have no other theory. You could hook a voltmeter on DC to the TPS or some other sensor and monitor the 5v supply. With the alternator disconnected and the engine running, it should be darn near 5v. You might get 4.98 or something like that. If it's pretty far off, like 4.5 or something like that, it would be interesting to see what the voltage did when you hooked up the alternator. I wonder if it goes way above 5v?
Just grabbing at anything at this point.
I like that theory.^
Yes monitor the 5v. I wonder if the PCM has tolerance all the way up to 12.8 but not 13?
Edit: Not sure what model it's for or how accurate it is:
I'll start by saying it's not a theory, I'm grasping at straws too 😂.
Edit: the thought process though is just that I've seen components fail in very unexpected ways, coils that work fine but short with a slightly elevated voltage, transistors that work perfectly until a tiny change in DC conditions... Rare but this issue is pretty unusual.
I said earlier that I didn't think it would be the computer, but I think we do need to enter that back into the conversation unfortunately.
This is very helpful thanks. I think this is likely to be the correct or at least a similar design to what I see in the photos. I won't try to explain what Ford was thinking with that power supply design but I can see several ways it could fail with unpredictable results, especially if it might have been exposed to excessive voltages in the past.
I'm with you guys at this point, I think he needs to check the 5V supply both on battery power and with the alternator connected (maybe even jumpered to another vehicle). This should help to see if the computer is freaking out or running properly.
Better than me. I studied it for about 30 minutes and still had no idea how the 5v gets generated...
I need to get on my desktop and really zoom in on that schematic, but I'm thinking it's not this exact computer but probably very similar. None of the part labels on the screenshot seem to match up with the silkscreen, but in the time I spent staring at it did look plausibly similar.
Basically you can see the power (12V) coming in at the upper left. IC6 is a shunt regulator which is setting the voltage and I believe Q1 is a 2N6107, if I'm reading the schematic right, which would be the pass element that's doing the heavy lifting as it can supply 7A.
If I'm seeing that wrong, someone please let me know.
If this computer uses the same or similar design, any one of the components in the upper left corner could conceivably screw up the 5V rail - problem is, I can't definitively say that's the right schematic based on what I can make out in that and the photos.
With just battery truck not running tps is at 5.07dc volts currently charging battery I've been using so I'll continue tests tomorrow
Injectors should be higher than that. From memory, about 14 ohms. Do they have a readable part number on them?
And are you checking them out of circuit (unplugged)?
Had no battery hooked up in truck when I ohmed injectors with harness on I'll take connectors off and check again and check for part number
