4.0L OHV 1994 ranger 4.0 engine replacement
Featured Build Threads
Belton
TX - USA
Other
explorer
Vehicle
Drive
none
none
Good morning. Recently picked up a 1994 ranger with a 4.0 and manual transmission. The engine has been disassembled down to the block and the heads are rusted through. I am combing the local yards searching for a replacement 4.0. I am finding very few rangers and b4000s and few earlier explores. There seems to be a decent selection of later explorers with the 4.0 ohv available. I'm assuming and will check most are automatics. Any tips on sourcing a viable 4.0 for this truck would be greatly appreciated.
  • 1994 ranger 4.0 engine replacement
91 - 95 Explorer
90 - 95 Ranger
94 - 95 B4000
Some 96's MIGHT have the correct 4.0, sometime in the 96 model year the camshaft position sensor went from 2 wire to a 3 wire system
Some 97's MIGHT have the correct 4.0, sometime in the 97 model year they went from a 6 bolt flywheel to an 8 bolt flywheel
I believe the camshaft position sensor can be swapped to the 2 wire style.
So, manual or automatic doesn’t matter much for engine. All of the 4.0 motors I’ve put in my Choptop (manual transmission) have been from automatics. The big thing is that the early 4.0 OHV had a 6 bolt crank and the later and an 8 bolt. There was also a whole pile of random changes to the motor throughout the years.
The motor in my Choptop currently is from I think a 95 Explorer. Still had the 6 bolt crank, so my flywheel bolted right up after I pulled the flex plate and spacer. I also pulled all the stuff off the top of the motor that didn’t match what I needed for my engine harness and all. Just swapped over to make it work and dropped it in.
Cam sensors are a big thing. The 91 Ranger harness and controls in my Choptop don’t use the cam sensor. There were 2-3 different sensors and 2-3 different cam synchros for each sensor. I have swapped to get the correct sensor for different applications but it’s a little confusing if you don’t know.
Just a little update I have been able to source a 4.0 compatible with the 1994. I am not an experienced tech and hoping for plug and play without many mods. This is my first attempt to swap replace an engine as matter of fact I need to get a lift of some kind. I can keep you guys updated. Thanks!
The 2-ton that Harbor Freight sells is a popular one. Personally I like using an engine leveler too, but it’s not necessary. I’ve changed a pile of engines though, like 14 or so… I’d really like to have a better setup than doing it outside on gravel though, lol. I put down sheets of plywood to run the lift on most of the time anymore
The first time I swapped an engine I rented a lift. Had to rent it twice.
When I swapped my current engine earlier this year I bought a lift off facebook marketplace or craigslist- can't remember which, for maybe $120. Iirc the new ones were north of $200- even the cheapest ones. I did buy an engine leveler and engine stand new as I couldn't find decent ones used.
Good luck.
I've always built an overhead with a chain hoist. (Except last time, I was able to use the 25T at work.)
For reference an Aerostar engine works too.
Thank you so much guys. The old block is still in the truck. May go the pre owned route or potentially rent. Thought about a homemade a frame and a hoist. Thanks and I'll know more before long
+1 for the 2 ton harbor freight hoist and absolutely getting a load leveler while you're there. I think the load leveler was $35 and it makes the job SO much easier being able to maneuver the engine without man handling it. Keep an eye on fb marketplace also, I bet you can save a few bucks on a used hoist
Upcoming TRS Events
Featured Ranger Based Vehicle
