> Oh NO!!... NOT the dreaded timing chain cover COOLANT LEAK! =:O
if you do not remove/mess with the cam synchronizer unit timing is merely aligning the dots.
it helps, but is not necessary, to set the engine at TDC before you start.
once the timing cover is removed the chain & gears are exposed, and you can see the timing marks.
now you can turn the engine over and align the dots. big gear points down, small gear points up.
then replace the gears/chain and put them back the same way.
the cam will have a tendency to jump around, just rotate it back to where you need it to be.
+1 , saved me from typing the same thing 😀. If you're not messing with anything else, just line up the dots and replace (lining up the new dots obviously).
One thing I'm not sure I mentioned in my posts but I'm sure others have elsewhere on the site is remember to clean out around that woodruff key in the crank and add a thin layer under and around it to prevent an oil leak there, along with the obligatory small amount in the corners where the timing cover meets the oil pan.
I've watched many videos and the timing change and water pump seems to be about time, patience and tips. I have removed the rad, ac bracket is up and the water pump bolts are untightened. I'm ready to do my 95 3.l, 2wd, supercab chain replacement but what I don't know...how to do top dead center?
I've tried to get two mobile mechanics to come do the job and it's a no call back. I find it comical that as a female, the lengthy effort isn't an issue but having all the knowledge.
I have to have it at top dead center before I even, impact the balancer off, right? I know to line up the basic chain and sprocket, once off. Any input so I can start to put my car back together. Tired of waiting for a mechanic to come do the timing part.
Welcome new Ranger owner/sufferer, please show us some pics of your 3.0 project, esp. timing chain slack, and any pitting/corrosion on your 30-yr-old timing chain cover, that way we all learn, thanks!
PS: how many total miles on your 2WD/engine?
I haven't touched anything beyond loosening the water pump and researching which brands to buy for the fan clutch and tensioner. I was trying to make sure I knew about top dead center first. I will take pics once I get time to do it..it's getting cold in the VA.
Mileage: My elderly cousin gave me his old, farm truck beater. The stepchild truck is over 200k. I will replace the plastic gear, next year. It's not a perfect truck but I like learning to wrench, it's a relaxing pass time and I'm saving $$.
Its been four months and I need to rewatch a few vids and catch the turning over part of the crank. I'm nervous but if I can just line up and put it back as, I've seen..it'll be ok.
I'll start getting the torque specs, for the wpump, balancer and cover, now. Thanks to everyone
Yeah, I once saw a very nice photo of the offending 3.0 TC + WPump, overlaid with text showing both the torque and the order of tightening... may have even had the bolt LENGTHS since there's at least 3(?) involved... it's not in the TRS Tech Library, but IIRC it was on this site... I'll Search for it, but don't anyone be afraid to post it first! ;)
>> Bing BING!... no time to deal with this for at least 3 weeks, WHAT is the best "stop-leak" magic formula that doesn't GUM things up?
(NOT surprisingly, the Form-a-Gasket jury-rig didn't work... gotta go INternal...)
Thanks in advance!
I have never had the Prestone Super Sealer clog things up. Later on once I drained the coolant, I would get a gell blob come out of the coolant system from the Prestone, but it never clogged anything. I have had the bars stop leak with the metal flakes clog things up.
I forget which stop leak it was but it clogged the heater core while plugging the timing cover leak. 99 sable with 3.0 Vulcan.
Might want one of these handy View attachment 135837
Well dang it, man, TRY to remember!... :D;)
(Are you posting the stud-remover because of the bolts which pass through the coolant channels?...)
I will tell you what I tried during a emergency, and it actually worked. Pepper that you sprinkle on your dinner. Took the top off the shaker and poured a good amount into the radiator, the leak stopped in short order. Couldn't believe it, but happy it worked.
Strangely, even though the Prestone website itself mentions Super Sealer in one of its articles, they don't LIST it under products, and no one seems to sell it any longer... was it found to cause brain cancer or something? :unsure::eek:
I didn't notice that till you mentioned it. You can't get it except off ebay. I see Prestone does still make a radiator sealer, but I have never tried it.
I will say I have found some of the others that tend to clog, work better by just putting a little bit in the system instead of most of the bottle. The cooling systems in these little trucks are not that big, whatever you get, just put in a little bit in at a time. Drive it and wait for the leak to stop. If it doesn't stop, but just a little bit more in it after it cools and try again.
I think that is what happened to me when I used the bars leak with the metal flakes. I put too much in. I did have a small leak in my kubota tractor radiator, and there was a little bit left in the bars leak bottle I had. So I poured that little bit in and it stopped the leak without clogging things up.
FWIW I would only consider using a stop leak product as a last resort. I've seen a few cases of badly clogged radiators - one I know for a fact was Bar's (Subaru branded).
Some formulations are only supposed to harden on contact with air, which sounds great in theory. I think if you have any air bubbles working their way through your cooling system though, these things will gum up over time.
I agree with the strategy of using the smallest amount possible. I would worry about any of these products decreasing the efficiency of the cooling system over time.
Yeah, weird... got some coming by slow-boat off of Epay... NONE of the auto parts chain stores carry even the newer/replacement Prestone leak sealer--SUPER weird!
They all carry only the Bar's products. :unsure: :icon_confused:
Wish me luck, will report back.
PS: got a quote from a local well-regarded shop, favored by the classic cars crowd, and it's $1,839 just for labor! :eek: Will get other estimates, incl. 2 Ford dealerships, just for grins/worst-case! :devilish:
