Oil & filter change. First time I've ever put 5,000 miles on the Ranger in just 2 months.
Ordered replacement filter for what I used, new oil filter and air filter for the snooperduty, which is due for oil change and new air filter, a case of brake clean and a few gallons of Rotella. Expensive day already. Grocery store later.
i have a 12k generator i bought 5 or 6 years ago in case we get hit with a bad hurricane and power goes down for a long period. it is multifuel but i have only ever run it on propane so the carb stays clean.
if it ever gets used in an emergency, it will most likely get run on gas and then i will have to worry about the carb later on.
i want to try and mess with a small gen to run on wood gas. that looks cool though it would probably be useless after a rainy hurricane since all the wood would be soaked
I've been kinda curious about that as well. Not enough to try it. Just curious non the less. Plus, the only small generator I would be willing to try it on is a two stroke. So, that kinda kills that idea.
Just took a long look at my Ranger then piled a lot of parts in the box - Now I gotta wait for our replacement short block to show up. Had to stay with the SBC combo solely for cost reasons but would give anything for a 390/427/428 FE to stuff in there.
Got a flush in, going to run it on distilled, drain, distilled, drain. Probably just the twice. When it's empty on the last one I'll put on some JB Weld, though it looks like the Bar Seal has stemmed the flow for now.
Found a 2.5l manual with 150k miles (2000). $4K. I may go get it next weekend.
