Looking for a 2.9L Mechanic in Atlanta Area
Did you take this back to a two pump system?
I didn't read all of it. But seems you wanted to take it back to original for some reason.
That is a picture of the frame mounted high pressure frame rail pump I removed from my 86 Bronco II.
Do you fellas need that?
Thanks. Yes we did take it back to a two pump system. From the looks of your gizmo, the angled piece on the bottom is still attached to the frame, but the rounded piece that holds the pump is long gone. We put it together with an abundance of zip ties just to get Peter back on the road, but the next time I’m going to fabricate something like that round piece to hold it properly.
The original feed and return lines for the fuel system are all chopped up. I put fresh injector hose in between the steel pieces (aftermarket, poorly done), and I’ll hunt for some of those the next time they have one in the scrapyard
Not sure why you put things back to a two pump system. A single in tank pump it arguably more reliable.
It does still have the fuel canister/filter between the tank and frame pump... right?
Yes, I put in the fuel filter that was recommended for that year and model. It was twice the size of the fuel filter that was in there.
I realize conceptually that upgrading the fuel tank pump could eliminate the need for two pumps, but personally, I am not that knowledgeable. But it was easy to figure out how it was originally. And since both pumps are now new, it should be reliable for a while.
Yeah... you may not ever have issues with it.
That two pump system was designed with a canister... reservoir/fuel filter like this...
If it ever has fuel delivery problems and it doesn't have that... it could be your problem.
Wow, look at that funky thing. I don’t think I’ve ever seen one of those before, and I’ve been around a long, long, long long time…
Mine is significantly taller than that but yeah. I've heard of people replacing them with a second filter. IDK if anybody ever said how it worked out though.
I've gathered that the tall reservoir is the one without the filter... That shorter one of mine (if ya look close it has finger holds around the base) has the paper replaceable fuel filter. The vehicle had no other inline filter all the way to the fuel rail.
When I first got my Ranger, i had an issue with oil pressure on steep hills. What I found was that there was significant sludge built up under the valve covers. This was slowing down how fast the oil dould drain back to the sump. It was worse on hills because the rear drain holes were clogged worse than the front. Cleaned up real good unde the valve covers(top of the heads. I stalled new valve cover gaskets, gave it fresh oil and it has been good ever since.
Peter was over here today helping me out, and his truck still has a little tapping occasionally, full of oil with a fresh oil change.
You mentioned it might be sludge under the valve covers. Peter was told when he bought it that it was pretty clean under there, and the valve covers look new, and I can’t see any leaks around them.
Here’s my question. If there is sludge on the top of the head under the valve cover, I know you can kind of scrape it out and muck it out with a rag or whatever. But what about the drain holes? Did they go straight down to the sump? We’re afraid of pushing sludge out of there and having it damage some other part of the engine. How do you clean the drain holes?
They aren't really a straight sjot to the bottom. I don't recall all the details of my cleaning. I believe I scraped, brushed and wiped whst I could and cleaned with solvent (brake cleaner or kerosene? Don't remember.) Then fresh oil and followed with another oil change soon after that one.
Let me see of I documented any of it in my build thread.
Edit: Sorry. I don't seem to have written that down.
Never seen it done on a 2.9 My dad dealt with sludge on a 4.3 Chevy when I was about 14 that he ran a small (but long like 18") drill bit down the drain holes. It then had a gallon and a half of diesel in place of the oil for about 5 minutes of run time... Sketchy shit.
@Peter_'86_2.9L_Auto & I went to the pull a part early this morning. I haven’t been in a while, and I’ve got a list, and we were notified that they had several of the first gen 1980s Rangers.
We got up real early, cause I know if you’re in the first 20 or 30 people there’s a pretty good chance you can get a golf cart and not have to wait on one. Turned out we were the first ones there, that’s never happened before. Well, we got there, and found out that they haven’t had golf carts in months and months. I’m happy to say that didn’t totally kill the day for me, I was still able to hobble around pretty good with Peter pushing all my tools in a two wheel wheelbarrow.
I kind of struck out, didn’t get to cruise around like I usually like to do, but Peter got a few tidbits, and he picked up a really nice OEM chrome bumper for the rear. When was the last time you saw one in good shape? It’s got a little bend in under the one corner, which is almost imperceptible, that I’m pretty sure we can pull out with a chain fall once we bolt it on his truck. So it wasn’t a loss for everybody.
Then we headed back to our respective houses to start working on the houses. Never ends.
Oh wise ones….
Question: how does the oil drain from the top of the heads down through the engine block and into the oil pan?
@Peter_'86_2.9L_Auto has an occasional mechanical sounding tap in his engine. I’ve asked about this before. @Curious Hound said it may be clogged drains from the head down to the oil stump.
I still have my heads from when I put the rebuilt engine in my 2.9, and we are going to look at how the oil drains through the head after lubricating the rockers.
Does anybody know if the oil goes straight down through the block, or what the pathway would be? If we take the valve covers off, could we run a giant pipe cleaner or mild wire brush something like that up and down the drain holes to free them up or to check for crud?
the drainback holes.....they operate on ancient majic, sometimes known as gravity. it can be effective with quality oil and filter changes and pcv system maintenence and air filter use for decades of operation.
of course.....in the case of the cologne design....there are challenges.
one being the flanged exhaust ports cooking the pan rails and promoting sludge/creosote type build up promoting valve cover leaks and restricted oil returns.
