Unloaded the new-to-me tires and wheels I picked up for the Jeep. Got a smokin deal on these but had to drive 2.5 hours to pick them up. The old girl made the trip without complaint.
Well I am TRYING to do rear brakes. First time for me. Took the shoes and hardware off. Found out the rear cylinder is toast so i went to get that off and the male fitting of the break line was rusted on. A couple of rounds of penetrating oil and heat and i finally got that to crack. I get the old cylinder off and go to put the new one on and it seems like the inlet on the cylinder is too big for the brake line. I was about to throw myself on the mercy of the forum and ask what gives. And then for some reason all the reviews i read today where people complained about the wrong part stuck out in my mind. Let me go check the part number on the box and sure as shit it was the wrong one. I was supposed to get two Napa 370061's and i got one of those and a 370031. I learned a valuable lesson today, check your part numbers.
Wait till you get the wrong part in the right box. The parts store often tries to say you swapped it... :rolleyes:
I'm curious if these dudes are gonna give me a refund. I messed up, but they messed up first haha.
I drove it. Mashed the pedal to the floor on a straight stretch. The V8 AWD definitely has more power than the 4.0L OHV, but something about the combo is right. Hits 105 on the 1 mile drag strip from a rolling start, but stops pulling hard around 90. Also no matter what I do at 90 it shifts into OD. Something in the system overrides the OD off button.
Something about the combo isn't right, not sure if it's the transmission/torque converter, AWD t-case, or the gear/tire.combo. The tuner also said that there was nothing that they could change to affect the overdrive turning itself on.
Finished fitting and welding in the other rocker panel in my replacement cab then started carving the passenger floor pan out to get it ready for replacement. I found that, much like the driver side, it's going to take some extra patches beyond the replacement pan, I'll continue messing with that tomorrow.View attachment 134862
BEst I can tell the rockers on the 85 are good, but the DS floor pan sounds about the same. Definitely going to need the standard pan replacement, but it feels like the rot runs down the door seam beside the seat. The front of the ds seat rail feels like it's floating. Also think there is some up the transmission tunnel that is t covered by a replacement pan.
That's the only real rust on the whole thing. Hoping that if I get around to fixing, I might be able to salvage patches from the totaled 84. It was hit in the passenger side back of the cab, so I'm hoping that the DS pan and tunnel is good.
Well, there you go! Find a gal who can weld who also has a garage!
Him and me both. Problem is finding them. Those types tend to hang out in said garage instead of places where you can meet them. Goes for us guys too. When the girls ask where all the good guys are, we're in the garage, yard, or woods, not the bars you're searching in.
In my case, it was cowl leakage that caused the floor to rot on both sides, when I removed the carpet it weighed better than 50 pounds and was soaking wet. The reason I'm going the route of doing that rather than repairing what I've got on the truck is because my current cab is structurally garbage, all of the structure around the cab mounts is shot and this one is in far better condition. Doesn't mean it's not a project though, haha. Rockers could have been fixed and straightened but I've had issues getting branches and such wedged inside of the cab corners in the terrain I wheel in.
It’s the fall, maybe you can meet a good gal at a hayride or whatever you do out in the country.
I can’t help you much with meeting a guy though, never tried that myself.
I figured someone would twist that, but couldn't come up with better wording.
Hell if I know what they do in the country. I might live there, but doesn't mean I socialize. Since I don't do bars or parties, I'm usually in the shop/house tinkering with something or sitting at a computer playing games, reading, spending money, or otherwise mindlessly wasting time.
In my experience, all those things are extremely appealing to women
If you have a fat wallet…
My wallet is fat... Lots of credit cards, business cards, licenses, receipts, etc in there. Unfortunately all of that stuff doesn't leave much room for cash.
Well, I did it again... another one followed me home, I think I may have a problem... This one found me, I was thinking of cutting it up for parts but I like it so much I may just drive it for a while, gah, i need help, haha.
Yesterday I got a little welding done on the green Ranger. Passenger side frame braces are almost complete, just one more weld bead to run there. Welder was running good and it was a pretty good welding day for me yesterday. Got cut short by having to go to the township meeting. I wanted to speak but I couldn’t think of anything nice to say so I kept my mouth shut.
Today I’m going to my private off-site storage location to raid my donor Explorer for more stuff.
Ordered some upper control arms, getting ready to pull the trigger on some body mounts, front ones are beyond shot. Praying that I don't have to weld anything to do the mounts.
Yesterday I managed to collect a number of things from the Explorer donor. Namely a section of frame, (I ended up cutting off one of the upper control arms and it’s mounts in the process so that came home in the name of being tidy), the fancy digital fuel/range/mileage computer thing from the center console (Eddie Bauer edition), and the fancy digital HVAC controls. Also managed to help with a couple odd jobs and have some laughs. Paul and his women went with me out there.
Today I took a look at the HVAC controls vs mine and determined that installing that and the fuel computer thing in my custom center console are not going to be as easy as I had hoped. Looking like I might have to pull the dash harness. I’m going to have to get an EVTM for the Explorer before I go through that hassle, but I do intend to pull the harness before scrapping what’s left of the shell, but that’s not happening soon anyway, so here we are in limbo. Build a custom truck they said. It will be fun they said. :tease::icon_rofl:
Whatever. Not everything is going to be complete when my green Ranger gets put back on the road. Hard facts of life. At this point I no longer care that it won’t be completely done, I just want to get back to driving it so I can work on something else.
Also got to go to the eye doctor today because I was worried there was something in my eye, possibly rust or steel. They did a bunch of checking and stuff and said they could see where something was stuck in there but whatever it was isn’t there anymore, so eye drops for a couple days and if it doesn’t get better to call. It’s finally feeling better. Don’t play with your vision. If there would still have been something in there (I couldn’t see anything and couldn’t get the sensation that something was there scratching things to rinse out, and knowing I had been cutting rusty metal, nope, not chancing it), it would have been the third time they patched up my eyes. Twice it’s been to fish out some organic matter that’s blown in there and stuck.
Went and paid the guy for the silver ranger I picked up a couple days ago, then worked on my replacement cab for the supercharged truck some more. The passenger side floor pan is just about done now, getting closer to finishing it up by the day.
Event Coverage
TRS Merch
