1994 Ranger 3.0 alternator stumped
Featured Build Threads
fa1rch1ld
Forum Member
El Dorado Hills
CA - USA
Other
Bronco
Vehicle
Drive
Got a 1994 Ranger on a trade. Battery will not charge from the alternator. Figured the quick fix would replace the alternator, still not charging. figured maybe the new alternator was bad. So put another one in. Still nothing.
I just tested the yellow/white striped wire with car off. 13v. So this is telling me that the circuit is complete because the battery is reading 13v and so is it at the alternator yellow/white striped is also reading 13v. Wouldn’t this tell me that the wiring has no short or corrosion? When starting the car it goes into the 12v range same at the yellow/white striped. When I plug it in, no jump in volts at the battery. What I’m I missing here?
  • 1994 Ranger 3.0 alternator stumped
I'm just a novice around here so bear with me.
Do you have an individual power wire that goes to the alternator?
How well is your motor grounded?
I just edited My last post in this thread.
I hope the diagram helps.
Had to edit this post as well.
I left out the word edit.
The ground goes from the battery to frame, correct? I just cleaned that connection up. Still nothing.
The negative terminal of your negative cable should have a branch on it that goes to the body.
Then the larger wire of the negative cable should go somewhere on your motor.
Believe it or not, I do believe mine goes to the bottom bolt on the starter.
The bottom starter bolt has some stud sticking out and a nut goes on to it.
I believe that's where my negative cable hooks up to my motor.
However my EVTM says it should be bolted to the driver side frame rail.
If I'm reading it right.
Look at G107.
I believe that's the ground wire or negative wire from your battery however you want to say it.
If I'm reading it right.View attachment 132638
Look at G107.
Yes, mine is mounted there. It seems pretty secure and tight. To unbolt and clean the contact area would be difficult. Not convinced that it’s the issue. But never know I guess.
This post might help
The primary ground wire on mine goes to frame, engine block, and one of the starter bolts. All one factory wire.
This post helped. I was able to track down the fault wire
Yes, that’s how mine is setup.
I'm glad you figured out the problem.
I'm also glad you posted letting everyone know you figured it out.
So what was the problem?
The B+ wire was not reading the same Volts as the battery. That indicated something was wrong with the B+ wiring. Following the line to the Fusable Link, it was toast. Ordered a new 12g fusable link and it fixed the problem—learning pains. Probably didn't need the new alternator.
Thanks for posting the solution.
Yes thank you @fa1rch1ld for posting what the problem ended up being and the fix as well.
Hopefully now you can take your truck and have some fun with it.
Event Coverage
Featured Ranger Based Vehicle
