What did you do to your 2019 and up Ranger today?
Short version of what this dingleberry does?
CMOS
It pumps water haha. It's a portable 12v water pump. I put it in a group 24 battery box. It's got a shut off for my propane water heater and a quick connects for a sprayer. It can also be used to fill my tank from a stream while out off grid.
New DPFE sensor arrived. Rock Auto, $20.
I got a delivery today.
I guess I’ll have to install my lift this weekend.
What's the plan on the OEM hose clamps? Cut them?
Dudes on 5G say you can just pry them off with a screwdriver. I'll get some small hose clamps or use zip ties.
When we changed Brian's, we found it a lot easier to put the hoses on before you bolt it back on. Just a little tip. We had to take it back off and put the hoses on first to be able to tighten the hose clamps.
Yeah, it looks that way.
Truck isn’t shifting terribly but it could be better. For $20, what the hell, might as well do it.
Why did you replace this? Function? Symptoms?
CMOS
It is supposed to fix the shutter in the trans. They get condensation in them and restrict air flow required for smoother shifts.
I drilled holes in the floor of the bed so I could install rivet nuts. They will allow the drawer box I'm building to be bolted down so it won't move while driving or when sliding the drawers open and closed.
Shifting is getting a little bit funky in the middle gears.
Installed a 2.5 inch leveling kit this morning. This truck is even easier to do syspension work on then the jeeps are. I am very impressed with how easy it was to install with just jaaks and normal hand tools.
This is kit from american trucks
One is already on in this picture. I didnt take a lot of pictures because it was so easy to do.
And there she is after a drive over a bunch of speed bumpa and dips to settle everything
I see some pics look sideways. I don't know why but it would be great if someone with the ability to right them, would do that. I dont know how to, apparently
