- Oct 13, 2022
- Magnolia, Texas
- 2.3 EcoBoost
Short version of what this dingleberry does?
CMOS
CMOS
If there is a pic I don't see it. What are you referring to? Link to thread or pic?Short version of what this dingleberry does?
CMOS
It pumps water haha. It's a portable 12v water pump. I put it in a group 24 battery box. It's got a shut off for my propane water heater and a quick connects for a sprayer. It can also be used to fill my tank from a stream while out off grid.Short version of what this dingleberry does?
CMOS
New DPFE sensor arrived. Rock Auto, $20.View attachment 131570
Dudes on 5G say you can just pry them off with a screwdriver. I'll get some small hose clamps or use zip ties.What's the plan on the OEM hose clamps? Cut them?
Yeah, it looks that way.When we changed Brian's, we found it a lot easier to put the hoses on before you bolt it back on. Just a little tip. We had to take it back off and put the hoses on first to be able to tighten the hose clamps.
It is supposed to fix the shutter in the trans. They get condensation in them and restrict air flow required for smoother shifts.Why did you replace this? Function? Symptoms?
CMOS
Shifting is getting a little bit funky in the middle gears.Why did you replace this? Function? Symptoms?
