I'm considering doing a dumb pointless swap in the future. Talk me out of it lol
oklahoma
Honestly, no idea why this came to mind, but it did. I had the silly idea to yank the 2.3 out of my Ranger and putting in an older engine, maybe a 2.9L into it. In my tiny mind my truck is a 1993, Last ones with the 2.9 were built in 1992, surely it'd be possible.... Right? I highly highly doubt it, but has someone else done it? "Why, why would you *ever* want to do this? Of all engines you'd pick a 2.9?" idk, why the heck not, my poor old 2.3 has a tick and leaks oil from... Everywhere. "Turbo 2.3 swap it" true, but where's the fun in that when you can put a dumber stupid poopoo doodoo engine in it? I can't think of any think more fun than to gut the entire engine bay and rearrange it for an even older motor! 😁👍
If i was gonna do something out of the ordinary. Maybe a 300 inline 6 would be different.
too bad you cannot get a mazda 2.5 to fit in there. those engines are freaking rock solid and have some power in the mazda3 and mazda6
Well... Swapping to a doodoo poopoo motor is dumb...
If you wanna be unique though.. the link gets you a motor AND a 6mt, along with an incredibly amusing exhaust note.. one infinitely better than the garbled mess an old v6 makes..
Stay 4 cylinder is the best choice, the truck is already set up for it. Rebuild the 2.3L, maybe hop it up a little with camshaft and compression bump. If you're feeling a little crazy, swap in a 2.5 from a later 90s Ranger, it's the same engine platform. If you want to go a little wild, forced induction on either of those. Maybe look at a gear swap if you want better performance out of it.
If you're going to swap to a V6, 4.0L is only logical consideration. The cost is practically the same unless you own the 2.9L drivetrain already. It is the same amount of work to swap the 2.9L and 4.0L. The latter is newer, more powerful, more reliable, and pretty much as good on fuel mileage. The good thing about either is that it can be a bolt in swap with pretty much all factory parts. Swapping in an older engine just isn't worth it, not to mention illegal per federal law. Per federal law, the engine must be same year or newer and retain the engine's emissions equipment. Of course if the vehicle is not in an inspection zone or is exempt, who is going to know.
The good thing about any of those is that they can be a bolt in swaps using all factory parts. You can get everything you need from a donor car and/or junkyard. Easily supportable through your local auto parts store.
V8 swap is pretty much the same amount of effort as a V6 to install, but isn't as much of a simple bolt in. An Explorer 5.0 drivetrain is a fairly easy swap into most Rangers, though the wiring can be a challenge if you want to keep the EFI. Being a first Gen you will need to change oil pan and pickup tube to clear engine cross member, IIRC Mustamg double sump works. Will require custom engine mounts, some body modifications to make it fit, might need a custom driveshaft. You will want headers that fit in the frame (stock ex manifolds suck) and exhaust to support it. That also means more money, and maybe more time, to put it in there.
When it comes to long term viability of engine swaps, being unique is not a bonus. I know that somewhat contradicts a thread I just created about swapping my F-100. IMO an old chassis with stock(ish) engine, is better than a newer chassis with an older less supported drivetrain. In that situation you're going in knowing that both are old and not well supported and everything is designed to work together. An old chassis with a newer engine is better than both, old style and supportability of a modern drivetrain.
OP has a 3rd gen, he has a 93, but this may still apply because he’s still TTB/TIB front.
Definitely headers on a 5.0, those Explorer exhaust manifolds…geeze, it’s a wonder they can run being that throttled…
You are correct. I should have said being a TIB/TTB.
I would avoid the GT40P heads if you want to do headers...
Flathead ford from a model tt ford truck. 201 c.i.d.
Now that would be a sight!
There used to be a guy around here that swapped a 2.9 into a 3rd gen, i think it was a 96.
Its not a dumb idea persay, the 2.9 will gain you what...40hp and probably 50 or 60ftlbs over the 2.3 (dont remember the exact lima output)....
Im not sure how close a 93 is to a 92 for wiring, insturments are the same, so with a 92 (maybe even 89-91) harness/ECM it shouldnt be that difficult.
Use 4.0 motormounts and youll also need a 4.0 trans from around your year to make it simple as possible.
Unlike Mr lima lover above the 2.9 isnt a bad engine as long as you keep it cool and dont mind some valvetrain noise, and as a bonus it can climb hills at 55 without matting it and dropping 3gears.
But all that said with the amount of work and swapping stuff you could have a 302. Yes its common, but its pry best bang for your buck
What Mazda 2.5? Their is one that's the same as the Duratec 2.3, which later became the EcoBoost. Either of those should physically fit OK except maybe oil pan clearing with the TTB/TIB. The 2.3 Duratec was stock after what 01?
2.3 Ecoboost swap it…
Haha Mr lima lover, I like that.
How could you not love the thing.. it's adorable! The sohc inline motor aesthetic is timeless.. tall.. thin.. like a pretty lady 🥰
Dude the 2.9 is one of the sexiest engines ever to sit in between fenders. Thin and tall at top...wide where it counts.
Plus its got a sassy personality.
so there
Before you start spending money decide what you want to achieve. If more power is the goal a 302 makes the most sense. If you can afford aluminum heads that'll help with the weight gain.
You can get a little more power out of the 2.3 during a rebuild- plane .030" off the head (get an adjustable cam sprocket because the existing mark won't be accurate) and install a mild cam.
If you just want to be cool and different, I saw a Pinto with a swapped in flathead V8 at Carlisle last year. He added a ton of weight t the front of the car and probably didn't gain any power but it was cool.
