- Dec 10, 2021
- Washington
- State - Country
- N/A
- Other
- 2023 Taco
- Drive
- 4WD
Probably my biggest concern with that rear end you have though, is parts availability, Mainly brakes and bearings
32 teeth on the drive shaft vs the 108 ring gear with a 355 gear is really close. you dial it in from there. but if you have a tone ring diff your golden.It's not dependent on gear ratio, It's mounted on the carrier so it's measuring axle shaft revolutions, it could care less how fast the pinion gear is spinning.
If you put the tone ring on the pinion flange between the pinion and driveshaft, then you need to account for gear ratio.
I keep forgetting about those pesky automatic transmissions.Unfortunately my 2002 ranger has the vss in the rear differential and it has something to do with the transmission. That's the only reason I need the speed sensor.
Doesn't the '03 get into the digital speedometer? So, the transmission swap needs GEM, PATS and instrument swap for even a manual to work correct.All this talk about messing around with axles... it might be easier to just run the yota axle with a 5 speed swap lol.
Bearing aren't an issue - the Toyota 1 ton axle uses normal Timken tapered roller bearings. And it is possible to reline both the shoes and the drums....not cheap, but possible. (I did a little homework before the cost/availability of rims slowed me down).Probably my biggest concern with that rear end you have though, is parts availability, Mainly brakes and bearings
Well dang. Those pesky new-fangled modern trucks are a real pain. I'll keep my old stuff.Doesn't the '03 get into the digital speedometer? So, the transmission swap needs GEM, PATS and instrument swap for even a manual to work correct.
Someone up in Edmonton grafted a RoadRanger shifter onto his Ranger when he did his dually.
Note: It doesn't matter which end of the driveshaft you add the external sensor to...adding it to the transmission end works just as good as the differential (you'd just need to re-route the wires, but as they go from the cab to the rear axle, they are more than long enough.)
The current wheels on that rear end i jave are 14", i would like to go with 16". Between 3 people we couldn't barely lift the whole thing, its pretty heavy.A few more thoughts:
Pull-a-part doesn’t have a big selection of Dually trucks, some pick ups, but nothing commercial I’m still thinking the Toyota or maybe an Isuzu axle with the wheels might be the most practical, not that there’s anything practical about the project, huh?
And I know your 2002 is a little bit bigger than my 97 and my 87, but I’m still thinking those wheels are going to be way too heavy duty and huge for what you’re trying to do. The Dually wheels on my C 20s were heavyweight and a challenge even on those trucks. The pre-electronic Toyota steel Dually wheels I used years ago probably weighed half as much as an F350 wheel. And the bullet hole design is pretty universal. If it wasn’t an exact match, with the right center caps, folks might not notice or it might be close enough.
I’ve never been to the pull apart in Augusta, but I’ve been to the three in Atlanta on a pretty regular basis for the last few years. The pull apart in south Atlanta has many more trucks than the other two here. I assume you’re aware that you can search inventory online.
That south pull apart is down by Moreland Avenue and 285 if you are familiar with Atlanta. There are also a couple of big rig truck yards in that area, and a couple other yards around town that deal with more commercial stuff. It’s a 2 1/2 hour drive, but if you get the right stuff, it’ll probably save you days on your build.
And I want to be careful what I volunteer these days because I’m a sick beat up old fart, but if you’re coming to Atlanta to do something or other, I’d be happy to help.
Im thinking about going the dana 60 route per recommendation from this group. I don't want to use the stock wheels and finding a nice set of wheels in the 16" range is hard. I've read that wheels from the transit, sprinter vans have the same bolt pattern. If I want to change the bolt pattern it will cost me an additional $1k. I got a quote from 2 places the other day so at the end it's going to get way to expensive after everything I will have to do to be able to use the toyota axle.Mount the tone ring here/ or at other end of driveshaft between the flanges if possible
Mine is an 02 with analog gauges.Doesn't the '03 get into the digital speedometer? So, the transmission swap needs GEM, PATS and instrument swap for even a manual to work correct.
That would be super nice.All this talk about messing around with axles... it might be easier to just run the yota axle with a 5 speed swap lol.
