- Jun 8, 2020
- North Carolina
- 4.0 V6
Hello friends,
As the title says, back in 2019 I bought a 2003 FX4 from the original owner with about 90k miles (now at 125k) but the motor was replaced earlier that year with a ford rebuilt unit from the dealer; apparently the previous one succumbed to the dreaded timing chain issue. I was given the receipts for it but they aren't the most specific as to all the work that may have been done. The motor did come with a 3 year warranty, which I thought was a good deal and basically seemed like I was getting a "new" truck. Well it started leaking oil toward the end of that 3 year period and they replaced the oil pan twice chasing the leak. Ultimately they determined the leak to be the rear main seal right outside the 3 year mark. Its not too bad so I decided to just let it be. Fast forward to today and there also appears to be some oil coming from higher up, and possibly around the intake manifold/pcv system. There's also a noticeable ticking, and is generally running a little rougher. A few weeks ago I got the 0171/0174 codes and found a bad leak in the pcv elbow by the throttle body which fixed the code. At this point, I'm assuming I'll need to do a general work over to get it running proper. I have already replaced just about every fluid minus a coolant flush.
My overall question is, what all might the dealer have done with the engine swap? Is it possible they didn't put new gaskets on things when the original was dropped and everything put back together? Things like spark plugs/wires, thermostat, sensors? The rear main really annoys me as that is something I'm pretty sure would have been new on a ford rebuilt motor. Oil is definitely coming from higher up though as there's a trickle visible from the passenger side wheel area going down the engine block, almost like its from the head gasket. I'm assuming this is the valve cover which requires a decent amount of work by the looks of it. The intake manifold would be on the list as well, as the knock sensor wire came apart when I was fiddling with the pcv hoses and had to splice it back onto the connector.
So overall, just not sure how far to go with the maintenance. What is original vs replaced with the engine swap?
I wish I had confidence in the work that was done, the dealer is well regarded it seems. The ticking has me worried as that is typically a warning sign of the timing chain issue, but I thought Ford "fixed" that with better guides, ect. What are the odds of that happening on an "new" engine they rebuilt? Am I just overreacting here? Any advice would be greatly appreciated!
