- Feb 13, 2025
- VA
- 4.0 V6
Hello all, I am in the process of rebuilding my 4.0 OHV and I’m at the point where I need to figure out pushrod length. I put in the Delta Cams 410 cam regrind so I was assuming I’ll need bigger pushrods. I checked pushrod length with my old stock pushrods to see if I would actually need to change anything and got the results shown in the attached pictures. From the pictures it appears the rocker is sliding all the way down the valve. Would this mean I need smaller pushrods? It is also worth noting that I had my rocker tips cleaned up by Delta cams but they told me that wouldn’t change the geometry. Any input helps thank you.
