Transmission compatibility
tibu911
louisville ky
Hello new to forum and owning a ranger
first and foremost sorry if this question has already been asked but i have a 1991 ranger 2wd with the 2.3L eight plug engine and my transmission has shit the bed on the stickers its a F17a Ka on the sticker
in my search for a replacement i have found in a junkyard near me with a 96 ranger 2.3 or 2.5 that is 2wd the sticker on the side denotes f57a aa i have also found a post online for a trans out of a 94 ranger 2.3 2wd with a sticker denoting f67a aaa from what i have read i think both of these will work but i am looking for confirmation and any help would be greatly appreciated
start here
i had read that post and a few other as well but my transmission mine is an m5r1 or M50D-R1 2WD that was ran dry of fluid evidently in the way that the first gear looks. from reading that what i understand any manual 4cyl 2wd transmission will work as replacement to the one in my ranger am i overthinking this by looking at the manufacturing stickers on the side of the trans ?
the lima block (all the 'old' 4 cyl) and the cologne block (2.8,2.9,4.0L) have different patterns.
So if you find a M5OD-R1 behind a 2.9 (the most common) it wont work (since the trans has the wrong mating bellhousing pattern).
You need to find another M5OD from a 4cyl donor for an exact swap, but yes one of the older FM's should work.
Look at the door sticker and under the hood (glance to verify 4 cyl) to narrow it down to 4 cyl and Code "M" if you want a M5OD.
that link broncc posted has the door code lookup if you want to add the FM's to your search - I don't remember em off hand.
1993
Transmission Assembly
5SP,2.3L,02/93
X​
240136
1047kg
$Call​
Auto Warehouse, Inc USA-IN(New-Albany) E-mail 812-949-2323
21​
1993
2.3L,MANUAL TRANS C-DATE: 20131106, -
X​
6709
1047kg
$500​
L & M Auto Salvage USA-KY(Frankfort) E-mail (502) 223-0229
26​
1994
Mazda Pickup Not Rotary B2300
MANUAL TRANS
X​
8001
1047kg
$500​
26​
1997
2DR,XCAB,TAN,2.3,5SPD,4X2,DRV
205,665​
C​
978406
1047kg
$400​
Bardstown Auto Wreckers USA-KY(Bardstown) Request_Quote 502-348-8613 Request_Insurance_Quote
Live Chat
30​
1990
2.3L MANUL 2WD
146,000​
A​
230736
1047kg
$485​
135 Auto Parts USA-IN(Mauckport) Request_Quote 800-428-2987 / 812-732-4352 Request_Insurance_Quote
Live Chat
41​
1994
PULLS GOOD
390,000​
C​
230406
1047kg
$485​
Live Chat
41​
1997
PULLS GOOD
263,000​
C​
230607
1047kg
$485​
Live Chat
41​
1994
X​
5C5444
1047kg
$Call​
Nichols Auto Parts USA-KY(Elizabethtown) Request_Quote 1-800-999-2702 Request_Insurance_Quote
Live Chat
42​
1996
MANUAL,RWD,RED,XLT
237,548​
C​
F2386
1047kg
$400​
Jay's Auto Recycling and Sales USA-KY(Sparta) Request_Quote 859-643-0877 / 859-643-0524 Request_Insurance_Quote
Live Chat
45​
1996
MANUAL,RWD,BLACK,XL
231,390​
C​
H2306
1047kg
$400​
Those are all in interchange records for your truck. M5OD was used behind the 2.3 Lima 88-97 and 2.5 98-01. The question is when did it loose the mechanical speedometer drive?
1993
5SP,2.3L,02/93
X​
240136
1047kg
$Call​
21​
1993
X​
6709
1047kg
$500​
26​
1994
MANUAL TRANS
X​
8001
1047kg
$500​
26​
1997
205,665​
C​
978406
1047kg
$400​
Live Chat
30​
1990
2.3L MANUL 2WD
146,000​
A​
230736
1047kg
$485​
Live Chat
41​
1994
PULLS GOOD
390,000​
C​
230406
1047kg
$485​
Live Chat
41​
1997
PULLS GOOD
263,000​
C​
230607
1047kg
$485​
Live Chat
41​
1994
X​
5C5444
1047kg
$Call​
Live Chat
42​
1996
MANUAL,RWD,RED,XLT
237,548​
C​
F2386
1047kg
$400​
Live Chat
45​
1996
MANUAL,RWD,BLACK,XL
231,390​
C​
H2306
1047kg
$400​
That is very helpful with the info I received yesterday I believe I found one that will work out of a 94 2wd with the 2.3 Lima engine that is 150 bucks and looks to be in great shape internally if that falls through I will definitely go with one of the units you sent thank you greatly if you don't mind me asking aswell how did you find this info ?
3.0's also differ from everything else. So thats another no for a 4 banger trans
www.car-part.com.
Basically a junkyard search engine.
You pretty much can grab a manual from a ~88 through '98 4 cylinder Ranger 2 wheel drive and be fine but after about '95 you need to grab the whole shifter because it's different, you can tell when the pinch bolt goes front to back versus side to side, or is it the pivot pins front to back versus side to side? one of the two... after '97 or '98 the speedo cable hole went away otherwise you could include through '01
Also along the years the slave cylinders changed, just get the right one for your year and go with that or you have to do too much monkeying with the hose and master cylinder...
Thank you all for your help I got the transmission put into Tuesday night with a new clutch throw out and pilot bearing as well as master cylinder while I was under i changed the oil pan gasket aswell and she's back running perfect
