- Sep 21, 2007
- Wa, Bremerton 98310
- Total Lift
- Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 32"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
@MajorKlozeoff
This is what i would do to verify timing:
*"verify first that your coil has sufficient output, THEN**
1) pull the passenger side valve cover
• manually rotate the crankshaft until both the #1 exhaust is seated and the #1 intake valve just fully seats
• verify the position of the crankshaft in relation to the pointer
• if it is spot on you are either at 0° TDC or 180° out
Snug (only) down the valve cover and start it up. If it doesn't start,
** reset the engine to 0° TDC, REMOVE THE DISTRIBUTOR ** (thank you @alwaysFlOoReD )**
, then manually rotate the crank 180°. Once starts up, warm it up to normal operational temperature, shut it down, disconnect the spout. Then Start it and set the base timing. NOTE, I do this with all lights on radio cranked and A/C on full arctic mode.
Once the base timing is set with the spout disconnected, shut it down, reconnect the spout, fire it up and see how it runs ..)
