Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 57
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
You have an 18.625" coil spring with a dual rate of 385/650. You're applying 1100 pounds to it. Your current coil spring has a compressed rate of 10.50" How much is the new coil going to compress and how much lift is it going to give you over the 10.50" compressed spring?
I've been working on a page about coil springs and I embedded a calculator to calculate spring rate, and one to calculate how much lift a spring will give you. I even have a list of springs with their lengths and spring rates:
Ford Ranger 4x4 Coil Spring Guide - The Ranger Station
Feel free to use the calculator there if you want.
My issue when calculating how much lift you'll get from various springs is factoring in dual rates. I searched the internet and could only find complex lengthy examples that dealt with dual spring coil overs. Not a dual rate coil spring. The spring below is your example. Tell me what height the spring is going to compress down to, the amount of lift it will give based on the information I posted above, and how you arrived at that answer. I have my own idea of what it is, but I want to see what you guys come up with.
I've never had to deal with dual rate springs, so this is new to me. Some of you may have an answer right away.
