- Jun 8, 2024
- south carolina
- 2.5 (4 Cylinder)
so i have a 1998 Mazda b2500 and every time i get gas i reset the trip meter and i have to fill up again at around 170ish miles. my math comes out to 10.5 miles per gallon. the downstream oxygen sensor was reading the same as the upstream. so i replaced the downstream and it was reading the same way, so i replaced the catalytic converter and the down stream reads normal. so its not a cat or o2 sensors. i have changed the dpfe sensor for the egr system and the connector for the dpfe sensor. the idle air control valve was stuck so i replaced that also. plugs, coils, and wires have been replaced about 5,000 miles ago. no visual fuel leaks and doesn't smell like gas after its been parked. idk why this truck drinks gas. I'm at a loss for what to do other than fuel injectors and I'm gonna get those checked out when i get the slave cylinder and clutch changed i plan on doing this soon just saving up for it. also i know the way i drive impacts fuel economy but i drive 10 miles to and from work and rarely get above 3k rpm that's usually when i shift gears. i think i drive alright im definitely not full throttle all the time i drive pretty leisurely .
has anybody had this bad of fuel milage or does anyone have any helpful advice? also the truck has 269,000 miles and i have no cel. i might can post some of the data from my scan tool if that helps.
