Project88
So years ago when I was a teenager I bought this blue bronco 2 from my parents rebuilt the engine to spec, plus 30 over bore and could never grab gears in it after 6 times pulling the transmission to figure it out and having no experience with manual transmissions and not being able to fix the starter grinding situation I parked it and left it outside after putting the distributor module relocator kit on it. Well I'm 28 now and been in the automotive mechanic industry for 10 years and watching a YouTube video from simonfordguy about his inline 6 bullnose it hit me what I did wrong I trusted a fastener company to get my bolts right on my pressure plate. You guys remember that the manual pressure plate comes with m8 x1.25 by 15mm long bolts right? Well when I was a teenager I couldn't get them off without stripping the threads and ended up replacing everything top to bottom bolts including went to match up one of the bolts at my local fastener company and they gave me bolts that looked right well I never questioned them but my pressure plate was always 5mm from touching the flywheel and was flush would torque to spec too so I assumed it was fine now the older me knows younger me was inexperienced and up until 3 weeks ago didn't realize pressure plates gotta be pressed flushed against the flywheel this was the problem all along the bolts I had gotten were 5mm too long so when running seemed like it was right, so 28 year old me is going to give it another try here soon in the spring time and see if the old girl has any love for me after sitting outside in the weather for the past 4 years. Wish me luck, I'm gonna need it. Also gonna swap the starter drive for an escort 1.9 drive and maybe just maybe have a fun relationship with my first truck again.
