Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
The fight has been ongoing, and it has been close.
It really didn't do too bad when I had the camper on it.
I replaced the noted connector. It didn't make any difference. Starting has gotten much worse as the weather has gotten colder.
I had to jump it to get into the barn, battery gave out before it would fire. Then after charging it wouldn't start again so my wife pull started it. I finally got the topper out of the garage and back on the truck so I can get the truck in the garage and really pick at it. Then I had to have her pull start it again to get it back into the garage. And she really had to pull it farther than she really should have both times, and really it seemed like it took awhile the one time in Kentucky too.
Last night I started doing the diagnostic pinpoint test on everything in the ignition. I checked the pickup and it it tested perfect. Next thing was to check the ground at the module... and nothing.
So I dug out the wiring going to the dizzy. Back when I was melting down DS modules I spliced in an actual ground wire, otherwise the entire ignition grounds thru the distributor base contact with the engine bock. It is weird, it is like in the 6-7 years the heatshrink shrunk more so one end was actually open. So I crammed my multimeter probe down in there and I have ground. Test the connector at the module and now I have ground there.
So I plug everything back in and hit it last night, it fired right off.
So tonight I go back out and I don't have ground at the module again. Give the splice the same probe therapy and I have ground again. Hit it again, fires right off again. As far as "cold start" goes, it is 32* out.
So later I am going to head back out and redo that and see if that fixes it.
