5R55E shift solenoid A (1-2) location.
RedRanger2006
Forum Member
Firefighter
Ontario
I've been struggling too find a diagram or something too show me what 1 of the 4 shift solenoids is my A solenoid (1st-2nd)
Here is the harness layout showing the locations of the solenoids. The numbers are the pin numbers in the large connector.
Here are the pin number functions.
Pin NumberCircuitCircuit Function
TCC power​
Turbine shaft speed (TSS) sensor signal​
Sensor signal return (for TSS)​
4
Transmission fluid temperature (TFT) sensor​
5
Torque clutch solenoid​
6
Not used​
7
Shift solenoid (SSC)​
8
Sensor signal return (for TFT)​
9
Shift solenoid (SSD)​
10
Shift solenoid power​
11
Electronic pressure control (EPC) power​
12
EPC solenoid​
13
Not used​
14
Shift solenoid (SSB)​
15
Not used​
16
Shift solenoid (SSA)​
Here are the wire colors.
1Black
TCC power​
2Red
3White
4Red
5Purple
Torque converter clutch (TCC) solenoid​
6
Not used​
7Yellow
8Red
9Orange
10White
11Green
12Blue
EPC solenoid​
13
Not used​
14Brown
15
Not used​
16Gray
Here is the connector.
TCC power​
4
5
6
Not used​
7
8
9
10
11
12
EPC solenoid​
13
Not used​
14
15
Not used​
16
What one of those would be for my #1 solenoid then? 7,9,10,14 or 16? Haha.
There is no #1 solenoid. There is A B C D solenoids.
I think you are correct. A solenoid would be wire #16. Wire 10 is common.
If im looking at the diagram correctly, it will be the solenoid on the passenger rear corner of the transmission, would you say that seems right?
Here's another picture of the valve body wiring. Only thing I can tell you is when you pull the pan off, look for the large round thing that is shown in the pictures below.
  1. 1. Connect shift solenoids SSA, SSB, SSC and SSD electrical connectors.
  1. 2. Connect the torque converter clutch (TCC) solenoid electrical connector.
  1. 3. Connect the electronic pressure control (EPC) solenoid electrical connector.
  • 5R55E shift solenoid A (1-2) location.
circled solenoid is my A?
