Incurable Fuel Leak
broncc
N/A
MA - USA
Vehicle
Ford Bronco II
Drive
5"
Giving my truck more money than it deserves.
I'm coming to the TRS in a time of desperation. I have tried probably five times now to seal my fuel pressure regulator to the fuel rail with no luck.
This is a 1994 motor. I didn't replace the regulator during the rebuild and it naturally had a rust failure 5,000 miles later. With the motor now in the car and the magic let out, I cannot insert the new regulator without cutting the o-ring. I have tried excessive amounts of grease (no molly compounds in it for clogging reasons) and even cleared any corrosion on the taper with some Scotchbrite. I'm running out of spare o-rings! 🙃
My question to you all is; how do you do it? I'm getting so sick of smelling raw fuel all the time. I really don't want to take the engine out or undo the intake...
Are you sure it's right o-ring?
We use dish soap on them at work.
we use crisco when building turbine engines because it mixes into the fuel and oil without causing problems.
and you can get those in the plumbing section at your local hardware store to hold you over if you need more o-rings. they aren't "proper" car part material but i ran them on the fuel injectors in my bmws for autocross for years
I'm finally back and able to focus on this car again. I'm home sick and managed to slink to the garage to measure my o-ring set...
OD 0.571"/14.5mm
ID 0.295"/7.5mm
WD 0.140"/3.5mm
I'm beginning to wonder if this is actually a set of fuel injector o-rings. I am unable to recall or find a receipt where I got this unlabeled bag.
OD 0.571"/14.5mm
ID 0.295"/7.5mm
WD 0.140"/3.5mm
You might be right,
Here are the injector O-ring measurements
I can't find anything on the size you need
Seems to me like there has to be some sort of edge somewhere that you’re catching with the O-ring. I’d really go at trying to make sure the taper and seat area for the O-ring is as smooth as possible. Smooth is important, an O-ring by nature will seal against minor imperfections as long as it doesn’t get snagged and torn.
Unless the O-rings for the FPR are different than injector rings and they’re just way wrong in size… but that still looks like you might be snagging a burr somewhere…
I’ve started using Vaseline on O-rings…
in the plumbing section, where you get the parts for your faucet, are o-rings in many many different sizes. i brought my stock old hard o-ring and found one that looked similar. it was little thicker and works great
i would use the help section at the parts store
I wanted to update the thread with some new findings. I got a really good look at the problem when I had the engine out. It seems that the o-ring is not the issue. Its the bubble-and-taper joint on the fuel return. I had much better leverage from this angle and I really cranked it down as tight as I was brave.
(I know this is wrong for many reasons, but I put some ptfe tape on the threads so anything leaking past the seal meets more resistance before leaking out.)
The leak is now more solved but not solved. I think the return line may have something wrong with it that I cannot see. Or the taper on the Delphi regulator I have is a little rough. Anyway, the fuel smell is significantly reduced. If anyone has a lead on an OHV return line please let me know. They seem to be obsolete and not made aftermarket.
I’ve wondered for awhile if it’s all just 37* seat and AN sized. If it was, you could use JIC or AN fittings
