Tried to rebuild my rear brakes. Sad outcome. Passenger side went well. Driver side, something is keeping the shoes from moving in to what should be the rest position. It seems like the spreader bar is holding them apart. Because if I squeeze the bottoms together, the top separates from the mani pivot boss. If I squeeze the top together, the bottom separates and they want to go off-center. I haven't checked operation of the parking brake cable yet. If that's stuck in a partially engaged position, I guess that could cause the issue. Everything came apart fine.
Also found my axle/spring u-bolts loose. Very loose in driver side. Just a tiny bit of play on passenger side. Hosed down the nuts with PB Blaster a few times. They won't budge. I'll try again tomorrow. But it looks like I need to source new u-bolts. I had these custom made at a big truck spring shop and they were expensive.
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
youtube.com
