- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
I put all the wheels on saw horses to spray, I think I just used two cans of clear to do all 4 wheels... for the saw horses I put them over the ends so they were at like a 45 degree angle to paint...
I've figured out how I'm going to do it I think.
I'm going to use 4x4x4 cutoffs and cut them into a v-block for each wheel with the miter saw for them to rest on while I'm spraying. This way since i will not be painting the the airspace surface at the same time (I'm going to pre-paint the airspace surface with epoxy primer and let it cure before I do the finish spraying on the outside), I can just rotate the wheels as I go along and then I can also handle them the same way when moving them inside for curing. this will allow me to refinish the rim edges while I'm spraying. All I'm left concerned about is the spray gun potentially blowing something enough to push it off the block, but I can easily steady them with mo other hand while i'm spraying to avoid that.
One question thought... should I leave the bead seats bare aluminum? Or should I spray it with epoxy also? I'm concerned about when an old tire gets taken off, the epoxy might fuse to the rubber bead over time and peel that off with it? I'm not sure which way to go with this one.
