Why Are the Upgraded Lights Dimmer? | Lasfit Reveals
LASFIT
Forum Member
Ontario. California
If you’ve been keeping up with Lasfit lately, you’ve probably noticed our recent wave of upgraded products. Not only have we launched the T3 turn signal lights with enhanced decoding system, but we’ve also released the new and improved L2-T20 series, building on the L2-T20 series.
One customer installed two Lasfit products on his 2012 Honda CR-V: the L-T10R (400LM/bulb) on the upper tail lights and the L2-7443R (800LM/bulb) on the lower tail lights. Surprisingly, the upper lights appeared much brighter than the lower ones! So, why does the upgraded L2-T20 seem dimmer than the L-T10R?
The answer lies in Lasfit's energy-saving design. The L2-T20 series is designed to operate at a lower brightness when the engine is off to reduce power consumption. When you start the engine, the voltage increases, allowing the tail lights to shine brighter. So, it’s not that the upgraded light is dimmer—it’s just more energy-efficient. Once you're driving and the tail lights are on, they actually become brighter than the L-T10R!
And if you're after the brightest red brake/tail lights, the T3 series is the way to go. With a whopping 2000LM/bulb (Max), it offers a whole new level of brightness, ensuring safer driving.
In summary, the L2-T20 series isn't dimmer; it's designed to save energy and shine at full brightness when you need it most—while driving. If you’ve got any more questions about the L2-T20 series, feel free to drop a comment below!
One of the biggest issues with going LED bulb on older vehicles is the turn signal bulbs. They alone do not draw enough current to make the flasher relay work properly causing slow blinking or no blink at all.
Do your bulbs come with built in resistors to allow enough draw for flashers to work properly just by swapping the bulbs?
With a stock rear 3rd Brake light housing and with aftermarket housings with built in LED's the bulbs, the LED bulbs will illuminate just enough to have a glow making it look like the light is on but extremely dim causing the need for an external resistor to be added. This is also a common issue with switching from incandescent to LED bulbs in interior over head lights also.
Do your bulbs also have a resistor to prevent this issue?
The turning indicator LEDs I received from them did.
Hi, our newly upgraded T3 series LED lights come with built-in decoders to solve the hyperflash issue, plug and play. And please don't worry; our bulbs come with a 45-day free trial period.
Here are the bulbs suitable for your 1994 Ford Ranger XLT:
#T3-3157D fit for your front turn signal: https://www.lasfit.com/products/315...ferral&utm_medium=forum&utm_campaign=T3-3157D
#T3-3157A fit for your rear turn signal: https://www.lasfit.com/products/315...ferral&utm_medium=forum&utm_campaign=T3-3157A
#T3-T-T15R fit for your3rd Brake light: https://www.lasfit.com/products/can...Referral&utm_medium=forum&utm_campaign=T-T15R
