oicunow
I have a 1988 ford ranger xlt 2.9l v6 automatic 4x4. The issue is around 2200 to 2500 rpm the engine decides to spit sputter n missfire. The tach goes crazy and the engine boggs down. It doesn't like when you demand power either. The truck will sit and idle for hours without a missed beat. Parts I've replaced are as follows. New iac, tps, 6 icms, intake air temp sensor, distributor, map sensor, cap,rotor,plugs,wires, 2 coils, relays, fuses, pigtails, spout plug, ignition switch, ecm, replaced all grounds and still cannot get it to take a bottle of act right. Seafoam injector cleaner and throttle body cleaner, oil change, alternator, fusible links. Next step is to rip that v6 efi junk out n drop in a 302 4bbl and fix ford's mistake. Any ideas would be greatly appreciated.
