- Dec 21, 2010
- Automatic
Hello all and thanks in advance for anyone willing to read the long-winded breakdown below and comment anything they deem helpful. I have a 2006 ford ranger 3.0. It was idling rough intermittently starting about 3 weeks ago but now has been doing it consistently. Pulling the error codes, I get the following codes consistently:
1. P0303 (misfire in cylinder 3)
2. P0316 (misfire detected on startup)
3. P1000 (System Redieness test not complete)
What I have been able to rule out:
1. Vacuum leak: I have hosed that engine down in carb cleaner and the idle though rough as all get out does not change
2. PCV valve: replaced the heated PCV valve on the driver’s side no change as far as I can tell there is not one on the passenger side
3. Spark Plugs/wires: have changed the plugs and plug wires with no change
4. Coil pack: have 3 brand new coils a motorcraft a duralast and a screaming eagle same idle with all 3
Not wanting to throw anymore money at the problem (PCV valve was 80$ not to mention the price of the coils) I was planning on doing some test this weekend to rule some stuff out.
1. Compression test on the number 3 cylinder as I have heard the valve seats are an issue with the 3.0
2. swapping out the #3 injector with the #1 injector and seeing if the problem moves to the number 1 cylinder
3. Renting a fuel pressure gauge to ensure I don’t have a low-pressure problem.
4. checking to see that the purge valve isn’t stuck open
Any other tests you guys could recommend would be helpful or any advice in general. I have read that bad gas could be a culprit so I put some injector cleaner and 98 fuel in it and have almost run a whole tank through it so I am not sure if that would be the case.
