- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
Hi guys, some of you probably already read my intro thread of the bargain basement Ranger Splash that I picked up. I thought I'd start a thread over here for the general shenanigans as I go through the process of resurrecting this thing... mainly as to not make a mess in the introductions sub.
1994 Ranger "Splash", 87K miles on the clock. 2.3L
Initial purchase price was 400 bucks and included dreams of the only problem being the blown heater hose. As of now, it's morphed into a head that got so hot that it busted a seam in between some of the valves.
Right now I'm talking with a well established and trusted machine shop that is local who *might* have a head for it. Total for the overhauled head will be 800 bucks. I can do slightly cheaper online, but having the culprit local is worth a little money to me in the case something goes south later... plus, I despise ebay and avoid it unless I've absolutely no other choices. Plan-B is one of the three junkyard units I've located, and doing a complete rebuild on one of those heads (and maybe the block if needed). At this point, it is unclear if my block is any good since compression tests with a head this jacked are unreliable at best. I'm starting work this week on stripping it in place so I can get a good look at the cylinders and everything. It *might* be ok due to the low mileage. If the bores are straight and in decent shape,, it's just going to get a dingle-ball hone and re-ring the thing and drop in new bearings while I'm in there. I just started disassembly, haven't gone far yet but I'm committed now so here we go....
So wish me luck as I go full-on stupid and spend way more on this truck than it's worth!
