It goes to the S terminal. So I'm not sure if the starter wire goes on the left side or right side. Have the positive wire and the fuse box wire in the left closest to the battery. I haven't connected the starter wire yetI don't think it's "I". Is the other terminal marked?
Since it DOES start, the starter relay obviously has a good ground connection. If it didn’t, it could not energize and send power to the starter.The right terminal for the starter wire from the ignition switch should be marked "S".
And the starter relay has to bolted down to work correctly.
It goes to the S terminal. So I'm not sure if the starter wire goes on the left side or right side. Have the positive wire and the fuse box wire in the left closest to the battery. I haven't connected the starter wire yet View attachment 91419Enclosed pic
Well ît done good so far started and starter disengaged. Hopefully I have it fixed. Thank you so muchActually, when the relay coil is first energized it could arc enough to create a magnetic field, pulling the starter in, then there's not enough ground to collapse the field when the starter wire goes low. In effect, locking up the relay.
Added: Now I see a mounting bolt in the latest photo, and there was not one visible in the first pic.
There are some fundamental misunderstandings here.Actually, when the relay coil is first energized it could arc enough to create a magnetic field, pulling the starter in, then there's not enough ground to collapse the field when the starter wire goes low. In effect, locking up the relay.
Excellent! Glad you fixed it.Well ît done good so far started and starter disengaged. Hopefully I have it fixed. Thank you so much
1. The purpose of the coil in the relay is to create a magnetic field to pull the switch contacts closed and complete the circuit from battery terminal to starter terminal.
2.When the contacts close, an arc is created. The only detrimental effects of this arc are that over time, it causes the terminals to become dirty and pitted. Eventually, due to the dirt and pitting or, if something causes abnormally high current, the contacts could actually weld themselves closed either temporarily until some physical vibration jars them open, or sometimes they get permanently welded shut.
3.When power to the relay coil is removed by letting go of the key switch, the coil de-energizes and the magnetic field collapses, allowing the switch contacts to open by action if a spring. No arc or magnetic disturbance from an arc has anything to do with this. That’s how it works.
4.When the contacts open, another arc occurs as the starter circuit is broken. More dirt and pitting on the contacts is the result here.
Now you know, from an electrician with 41+ years of training and experience.
