- Oct 1, 2021
- State - Country
- TX - USA
- Other
- 2004 ford ranger
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 EcoBoost
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- Stock
- My credo
- drives a stick shift ranger
when you pulled the hose to replace the clamp, there wasn;t any build up on the hose flange of the radiator? nothing that would present a ridge to keep the hose from sealing properly? it sounds like a crack but the only way to find out is the pull the hose again and look. or, build up in the hose is keeping it from seating properly. was the hose really hard feeling at the clamp area? might have to trim some off so its pliable again
and if you are doing that, might as well get that other hose just so you are ready if this old hose is cracked or bad
