Jake_C
- Sep 8, 2022
- Ohio
- 4.0 V6
- Total Lift
- None
- Total Drop
- None
- Tire Size
- 235/75/r15
I apologize I know this has all been covered probably a hundred times. I’ve read up on this for weeks but am having trouble figuring out what I’d need for my specific application. I have a 97, reg cab long bed, 4.0. m5od r1 transmission I assume. BW1345 electric transfer case I assume again. 8.8 rear end. I understand that an a 5.0 from an explorer from the same year would be ideal because the engine wiring would plug strait into the chassis harnesses. So would a f150 of the same year with the correct motor not also plug right in? As far as I understand I want a 96-97 5.0, with a m5od r2 transmission with whatever 4x4 transfer case is already on it. Is there a vehicle that came with that combo in that year and is it practical to try to find one if it does? Am I totally wrong with these details? I know old gm motors and transmission and very little about 97 era ford stuff. If I did the swap I’d want as much plug and play as possible. Thanks in advance!
