motor and trans mounts for 2.9 v6 dana 35 4wd
Featured Build Threads
stamina
Forum Member
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
is there a difference between the 4wd and rwd mounts, can someone help me out here or post a link to a motor mount kit? the one on rockauto states rwd but it looks all the same to me. motor and trans mounts, i want to do all of them in one go
I think the motor mounts are the same. Trans maybe different because on a 4wd you have a transfer case instead of a tailshaft.
Go on autozone or something and compare part numbers.
Don't limit yourself to rockauto. You can research parts on other sites also. I looked up a 1986 ranger with a 2.9 on Autozone, and the drivers side motor mount is different between the 2wd and the 4wd.
Might be due to the different crossmember....didnt think about that
yea dude i checked other sites, it’s pretty hard to tell the difference between little pictures, best i could find is the 4wds made after 10/90 were different mounts for the trans and my truck is the 90 so i have to research vin to find when it was made🤦‍♂️
Look on the door tag.
Plus part numbers are better then shitty little pics to compare by.
Welcome to owning a Ford. They were famous for changing things mid-year.
I would not go by the pictures, who knows what they have in the picture. Make sure you go by the part numbers. They do not like to keep a bunch of stuff in stock on the shelves, so if it can interchange they will do it under one of their part numbers.
i figured it out. 2643, 2641, and 2639 driver, pass., and trans for 4wd before october 1990, mine was manufactured february 1990 different trans mount after october 90
Event Coverage
Featured Ranger Based Vehicle
