Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
Interesting OEM first gen part numbers for future reference:
E5ZZ-18813-A - 83-88 (maybe to 92?) Radio Antenna
E3TZ-9133-A - Fuel Cap Strap
E27B-8c020-AA, E3TZ-8213-A, E4TZ-9842528-A : Grille Oval, Hatch oval for BII
E3TZ-17A553-A : Wiper Switch W/O intermittent wipers
E3TZ-1004104-A7U : Tan Sunviser
E3TZ-1020910-ASP : Door Edge Guards (aluminum/chrome)
E3TZ-9932230-D : Bed Rail Kit, Aluminum Fence Style 7' Bed
E5TZ-9900064-A : Chrome Box Tie Downs
E3BZ-3600-AC : 83-84 Two Spoke Steering Wheel Blue (turn signal mounted horn and speed control)
E4TZ-3600-A : Same in Black
E5TZ-13341-AA : 85-88 Turn Signal Switch
E7TZ-10280A59-A : 83-92 Standard Cab Cab Corner
E3TZ-1K105-B : 83-92 (D28) Automatic Lockout Hubs, Pair
E3TZ-1028160-A : 83-88 Rear Door Post Panel (inside door area)
E3TZ-2162-A : Brake Master Cylinder Cap
E7TZ-16720-E : Black "Ranger" fender emblems, 83-88 Font
E3TZ-1010128-B : 83-?? Standard Cab Passenger Side Cab Rocker Panel
E8TZ-16450-A : Aluminum Running Board Kit (6' Long)
E8TZ-14527-A : 85-92 Drivers Side Power Window/Lock Control Bezel, Red
E5TZ-8592-H : 83-85 2.8 Upper Thermostat Housing Water Outlet w/ Gasket
E3TZ-10887-A : 83-88 Gauge Cluster Lens (1)
E5TZ-1021813-A : 85-88 Drivers Side Door Latch
E3TZ-16796-A : 83-88 Ranger/BII Hood Hinges (pair)
E5TZ-14529-A : 85-92 Passenger Side Power Window Switch
E7TZ-14521-A : Power Window/Lock Gasket
E5TZ-1130-D : 83-88 Red Wheel Center Cap
E3TZ-1137-A : 83-88 Red Center Cap Applique
E3TZ-9943400-G : 83-92 Tailgate Latch Handle, Black
E6TZ-5084-A : 86-97 Cab Mount Bracket (Extended Cab?
E3TZ-17618-A : 83-88 Washer/Overflow Jug
E2TZ-1021984-E : 83-85 Door Lock, Black (both sides)
E7TZ-16612-A : 83-88 Ranger Bronco II Hood (yes the whole big hood)
E6TZ-1021999-A : 83-88 Door Lock Grommets
E7TZ-10718-A : Black Plastic Battery Hold Down
E9TZ-13405-A : 83-92 Left Tail Lamp Housing
E43Z-19986-A : Blower Motor/A-C Switch Assembly
E0AE-9C915-A2A : Carburetor Bowl Vent Solenoid
E3TZ-1061748-A : 83-92 Bucket Seat Track Cover
E3TZ-13200-A : Amber Turn Signal Lens RH
E3TZ-14413-A : 83-88 Glove Box Lamp, Switch and Wiring Kit
E3TZ-8150-C : Chrome/Argent 83-88 Grille
E8TZ-15200-C : 88-90 Marchal Driving Light Kit (with wiring, switch and relay)
E8TZ-10044D70-D : 86-88 Brushed Silver Dash Bezel (Big Single Information Center, Single DIN Radio)
E8TZ-10044D70-E : 86-88 Woodgrain Dash Bezel (Big Single Information Center, Single DIN Radio
F0TZ-14401-D : Under Dash Harness 1990 Ranger or Bronco II without cruise control, without power windows or locks, and with manual hub locks (models produced before 2-1-1990)
F2TZ-14290-F : dash panel to headlight junction wiring harness for a 1992 Ranger with a 2.9L 6 cylinder motor but without "power group"
E9TZ-14401-D : under dash wiring harness for a 1989 Ranger or Bronco II with a 4 or 6 cylinder motor with cruise control (specific to these vehicles and year). It also specifies "without electric shift, without rear window wiper, without premium sound, and without power windows/locks".
F2TZ-14290-B : under hood wiring harness for a 1992 Ranger with a 3.0L motor and without power group
E9TZ-14401-H : under dash wiring harness for a 1989 Ranger or Bronco II 4x4 with electric shift but without premium sound and without cruise control.
F0TZ-14401-E : under dash wiring harness for a 1990 Ranger without cruise control but with electric shift and auto hub locks, or a 1990 Bronco II without cruise control
F2TZ-14401-N : under dash wiring harness for a 1992 Ranger 4x4 with electric transfer case, auto hub locks, with power windows, and power door locks
F2TZ-14290-A : dash to headlight junction wiring harness for a 1992 Ranger with a 2.3L 4 cylinder motor
E3TZ-15k233-A : Foglight cover. Shows "Ranger" in first gen font in parts book. Subs to E9TZ-15k233-A with a Ford oval
For the above light kit:
Ranger Fog Lights; similar to other '75-91 Ford trucks.
'80-86 Bronco/F Fog Lights
D9ZZ-15K233-A Lens Cover
D9ZZ-13466-A Bulb
EOTZ-15237-B Socket & Wire
EOTZ-15A245-A Bezel
EOTZ-15200-A Fog Lamp Assembly
EOTZ-15L203-A Lens
E4TZ-15200A : Foglight Kit
E8TZ-15200-C : 88-92 Fog Light Kit
D9ZZ-13466-A Bulb
EOTZ-15A245-A Bezel
EOTZ-15L203-A Lens
