How to Pull ABS codes on 99 Ranger 2wd
Ummm another shot in the dark, did you check your brake fluid? Pretty sure the ABS light is the same light for the fluid level.
Also, don't the ABS codes/data actually come out of the GEM module not a stand alone ABS module?
No, on both counts.
Red brake light is for parking brake and low fluid. Amber ABS light is for ABS. A low fluid condition will trigger both lights though.
The GEM does not power, control, or speak for the ABS module.
I somewhat suspect the OP has RABS, it is harder to talk to.
Nice way of saying I am screwed lol lol. Thank you for your help ! I do really appreciate it though
So I get the OBD Link EX get it all setup on Forscan and go to the truck to pull ABS codes and nothing. Doesn't even to be reading the ABS module.
That strikes me as rather odd that FORScan doesn't see an ABS node at all. If it's on the OBD2 bus, then FORScan should be able to see it.
For comparison, here's what FORScan shows for my 2004 Ranger:
Some thoughts....
Before starting FORScan, do you have the key fully turned (i.e. to the position where, if you turned it any further, the vehicle would actually start)? On my 2004 Ranger, none of the nodes communicate unless the key is fully turned, but I know of some GM vehicles where all of the nodes except the ABS and airbag ("RCM" in Ford terms, "SRS" in GM terms) nodes will talk with the key only partially turned. (I really don't think that's the issue, but I'm trying to cover all bases.)
You might want to try running FORScan after you've started the vehicle, just to be sure that all nodes are communicating. But be careful what you do when the vehicle is running. Checking for codes is safe, but some other things may not be (e.g. clearing codes, resetting nodes, etc).
Do you possibly have an electrical issue (e.g. bad or intermittent fuse?) with the ABS? I'm not familiar with the 1999 Ranger but, again, I really would not expect FORScan to somehow fail to detect the ABS node, assuming it's on the OBD2 bus.
BTW, DTC (Diagnostic Trouble Code) "P1000" on the PCM node tells me that someone has recently done a reset of the emission-related DTCs. That's not a big problem, but I would avoid doing that in the future unless it's necessary because it resets "freeze frame" and other important data and also invalidates all the "vehicle readiness monitors" too, forcing you to complete one or more "drive cycles" to prepare the vehicle for any possible state emissions inspection. If your problem is really ABS-related, then it's a NON-emission thing and doing the typical "clear codes" thing that most tools offer is typically not recommended and may even just confuse the issue.
Just curious... do you know why that is the case? Do you know what protocol it uses (e.g. ISO 9141-2, SAE J1850 PWM)?
I don't know what protocol it uses.
It's hard to talk to because it is a lesser module, not as sophistocated as a 4WABS unit. It should be on the OBDII network by 99, but they stayed on a dedicated diagnostic plug longer than 4WABS.
Yeah it is fully turned.
Gonna run out and try it in a few and try it with vehicle started.
I mean I checked the fuses and all look good but I can swap them just for the heck of it. But from my experience the light ALWAYS comes on after I reach 10-15mph and NEVER comes on prior or at a diff speed
Yeah the P1000 I looked up and it is because I tried to clear the ABS code by disconnecting the battery and google says I need to drive it for a while for some monitors to register.
No problem. I was just curious because OP showed PATS as being PWM whereas my Ranger only has the PCM node using PWM protocol.
Interesting. If it's an honest-to-goodness node on the OBD2 bus, there are ways to "ferret out" the nodes and it could be manually queried, but I really would think that FORScan would've found it. The fact that it didn't makes me worry (for the OP's sake) that maybe it's not really on the bus.
Oh, @99Ranger4.0XLT I forgot to mention. You might want to check the "BPP" (Brake Pedal Position, or it might be "BOO" in FORScan for "Brake On/Off") report as you press and release the brake pedal. That goes to the PCM, so you should have no trouble reading that. EDIT: That may only be true if you have 4WABS, not RABS. Sorry for any confusion.
If its RABS its easy to fix. Remove every part of it and chuck it in a river...
Dumbest brake system ever conceived.
You guys are talking a different language about nodes and protocols lol lol !!!
Also truck on still doesn't read anything different than truck off.
BOO in FORscan says on:
Sorry. "Node" = "module". PCM, RCM, GEM, and ABS are all examples of modules that talk to you on the OBD2 connector, using one of several "languages" ("protocols").
OK, good to have ruled that out.
Not enough info. Is that with you pressing the brake or not pressing it? Test it both ways.
In fact, I edited my earlier post because I saw evidence that the "BOO" signal may not be present at the PCM on a RABS 1999 Ranger. Do you know whether your Ranger is 4WABS or RABS? I don't know the easiest way to tell the difference. I'd look for wiring to the front wheels to confirm 4WABS, but some of the veteran Ford guys probably have a quicker way.
That late a RABS system should have front speed sensors too.
Quickest surest way is to find the ABS unit and look at it. Two brake lines is RABS, 5 lines is 4WABS.
OK, so only 2 possibilities at this point:
  1. FORScan is not smart enough to find an RABS module
  2. the RABS system is not sophisticated enough to be on the OBD2 bus
I would bet on the latter of those 2 things.
Regardless, diagnose what you can with what you've got until your rear speed sensor arrives. Repeating from my earlier post:
Also, see if FORScan offers any other PCM-module, brake-related PIDs (Parameter IDs) that you can monitor, other than "BOO" (Brake On/Off). Maybe not, but it's worth a look.
Also, I forgot to ask earlier: Is your red dashboard "BRAKE" (not "ABS") lamp illuminating as part of the self-test when you turn the key fully on? It should also illuminate when the parking brake is engaged. Does it?
Yeah pressing brake on and off and BOO only says on. However i did not try it while car was on.
Yes the Brake light IS on. Also lights up and light goes off when the parking brake is engaged and disengaged, ALTHOUGH I did have to put some wd 40 to get it to light up a few weeks ago.
ABS rear speed sensor came in and it DID NOT fix it.
I changed the brake switch a week ago, do they make separate brake switches for the 4wabs and the RABS. Maybe they gave me the wrong one. I did buy 2 from different stores in hope one was bad.
I appreciate everyone for sticking with me on this one.
