- Oct 15, 2020
- New York
- 2.9 V6
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
That is a factory transmission cross member. 1st gens used that and newer models had a solid mount. Can't get bushings for it so the solid mount is preferable. Not like it flexes much anyway.
You have a Rancho lift. I recognize the radius arms and drop brackets. Not the best thing out there, but it was safe unless you like jumping or rock crawling.
I have a set of the same extended radius arms. Trying to decide if I wanna use them. Apparently they rub the tire when turning? Does yours?
gotcha I’ll source a replacement tranny cross member.
ill check out the tire rub. I don’t think so, but that could also have to do with whatever the offset of these rims are vs OEM rims. Maybe it just clears..
