- Aug 6, 2007
- Shangri-La
- State - Country
- GA - USA
- Drive
- 2WD
- My credo
- Alas poor Toonces; I knew him well.
You're getting good advice, and franklin2 is describing a good way to do it, and why. You do need to find cylinder #1 TDC on its compression stroke. It helps to first clean up the timing marks on the crank pulley; find the 0 mark, and paint it or chalk it so that you can see it better. The "finger in the #1 spark plug hole" does work good.
Try to get a good look at the distributor hold down bolt; if it's the original bolt it may have a security-type head. If so you'll want to know ahead of time if you need to get a specialty socket (most have gotten replaced by now with regular hex bolts, though).
