Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
For the most part mine works great, sometimes it surges though. On our trip to Ohio it seemed impact related, hit a big bump and surgy surgy until I pulled the vacuum line off the servo. One time I hit a big bump and it got to surging and then I hit another railroad crossing and it came out of it. It only did it thru Illinois on the way out (they have a crappy highway), across Iowa, Indiana and Ohio and then the whole way home it didn't miss a beat. It did it again after it sat all winter... until I pulled the vacuum line off the servo and it has worked perfect for two days now.
Vacuum reservoir and lines were new last fall, I have tried two different amplifiers (one for a 2.8 BII and one for a 5.0 F-150, it hisses when I pull the vacuum line off (engine not running) so the checkvalve and dump valve are holding... so I did some digging and found this:
www.fordforums.com
Kinda makes sense, the valves are gummed up and stick if it gets bumped the wrong way. Since it works most of the time I wondered how hard it is to clean and lube the valves in what I have... I have a kind of crusty looking spare so I did an exploratory on it... and I don't see much and the two motor looking things don't want to come out:
How the system works:
Electronically the servo tests fine as per the EVTM, Ford shop manual and a neat thing I found here. The thread about fixing your servo looks like it might be in some other country (Australia maybe?) so they might have something different than what I have. I could keep grabbing them out of the JY hoping for something better or snag a NOS that might be a few years newer than what I have or get a $100 rebuilt one from who knows where... nothing really appealing and there is no actual valve test in any of the Ford literature I have found.
Has anybody else delved down this rathole?
@19Walt93
Cruise Control Surging
Does anybody know why my cruise control surges sometimes and not other times? Say I turn the cruise on at 100kph, the speed may drop to 98 then accelerate up to 102 and continue to cycle like that (on a totally flat road). Other times it works fine and hold the speed completely constant. Car is...
@19Walt93
