franklin2
You are running the original carb setup correct? Look on the back of the carb, you should have a piece sticking out the back of the carb with a wiring plug on it. Unplug that plug. Did the tick go away?
Actually the second time I’ve heard of this... unfortunately did not fix the problem.You are running the original carb setup correct? Look on the back of the carb, you should have a piece sticking out the back of the carb with a wiring plug on it. Unplug that plug. Did the tick go away?
I know it isn't what you want to hear but I'd want to tear it down and check everything, there's apt to be nasty looking stuff like that throughout the engine. If you want to try something else first, but some generic, inexpensive 10w30 and a few filters and change the oil multiple times- maybe every few hundred miles to see if the oil clears up- before dumping your high zinc oil in it. Zinc will ruin the cat if the engine burns much oil, if it doesn't burn oil great. Zinc in the oil won't fix wear and damage that's already been done, it's essential when breaking in a flat tappet cam, though.
If you're in a warm area you could probably get away with using 15w40 diesel oil,it's thicker and sticky and might improve the pressure if the problem is worn bearings with excess clearance. Ford never used to have an idle oil pressure spec, it was usually 1500 rpm or so but I'd suspect 5-7 psi is too low. What are you flushing the engine with? If it breaks sludge loose and clogs the pick up screen it'll be tear down time. I'd rather see multiple oil changes instead, just to be safe.
You can put thicker oil in it, and then just turn the radio up. But low pressure is a sign of a more serious problem. I would look for another engine, and run this one while you get the spare fixed up and ready to go in. For most engines, you should have 10 psi per 1000 rpm. Most idiot oil light pressure switches come on at 5 psi or below, so you would probably have a blinking oil light. Sounds like it's just wore out, it happens.
Kioti! I have an LK3054, great machine.I've never had faith in those mechanic-in-a can "fixes". I would much rather see multiple changes with clean oil, maybe with one quart of atf mixed in to add detergents, instead of dumping mystery goo in there. It's correct that thicker oil won't fix a worn out engine but it might get the pressure up high enough to keep it running for a while. I've said before that I'd rather tear it down but you've said you're not in a position to do that right now. I just wouldn't drive it 500 miles on the highway until you know how it's going to act. Diesel oil will work fine, I use some of the leftovers from my Kioti tractor in my John Deere lawn tractor during the summer. I do consider 50 degrees to be warm, the first 50 degree day in the spring the techs will leave the overhead door on the shop open.
