Junk Yard Hunt For 16's or 15's
Jay11
Texas
'99 4.0+'98 2.5
1998 Auto. Ranger XLT 71k miles
Am gonna sell this truck in about a year. To keep a tight budget am planning a trip to the junk yard to get some tires/wheels.
Am in need of 4 tires/wheels. I would like to upsize from the current 225/70R15 to 16's but also open to same 15's for a good set.
15's Steelies would be fine to as I can swap those into current 15's stock rims.
Besides explorers what other makes/models are a match I can look out for?
Mountaineers, Areostars, Mazda B-series, Navajos, all should have the same spacing, Mustang, Edge SUV, and some other rims fit but have different back spacing
I think any of the panther cars are the same spacing (crown vics and the like)
Facebook marketplace way better than Craigslist
Occasionally “letgo” has had wheels. I’ve thought about some white spoke wheels to go with my vintage look, new ones are nearly 70$ a rim- for a steel white spoke rim. Crazy! I remember them being 30$ per rim in the late 80’s new.
Am open to a great deal for me FB, LetGo, JunkYarda has potential to score a deal I can't say no to. Alums. are 40bux each and wednesdays are buy 1, half off 1, total 120 bux, while Tuesday's are 15 bux for each Steelie.
Am driven by how much I can get away with on a good set of 4. Cheapest I have seen on CL is 250 and and up to 6...900 bux.
With your added suggestions this ranger will have a "newer" set of shoes in no time.
Same bolt pattern, same backspacing until 2002. In 2003 Ford redesigned the frame and switched to a more modern front wheel drive backspacing, so any '03+ rims are going to look excessively "tucked" and you might run into clearance issues. Anything pre-02 should be fine.
Facebook Marketplace... Here in the Chicago area there was a pregnant grill went onto that site for some cheap baby stuff. She went to someones house... they killed her... took the unborn baby from her body... put the cut up mother in the trash. The baby was about to die but the killers went to the hospital said she gave birth at home and to please help the child. Last I heard the child is on life support and through the mothers digital footprint... and the hospital staff... three people are in custody and hopefully rot in prison. True story...
Just not so sure how much better it is... Facebook
Will newer explorers say after 2010 to current, with 16's fit?
And would something adverse happen with 17's from some of these cars, say to tranny ... differential ratio being thrown off balance or being short-lived? Am asking ahead of time because I have seen some of those sizes. I don't mind a Speedo that's out of cue a little bit if that's all there would be with 17's.
Not much different than the classifieds of old.
I like to meet in public places during daylight. I bought a Coleman lantern on FB marketplace awhile ago, guy was more than happy to meet me in front of a huge Cenex gas station (full of people and cameras) at 3pm. Anything went sideways there would be tons of witnesses and it would be recorded. Elderly Vietnam vet (according to his plate and hat) was on time with no funny business.
If they want to meet you behind a dumpster in the bad part of town... either push for somewhere else or end negotiations.
'11+ may have issue with lockout hub/hub cap fit. Offset will be way too tucked and may cause adverse wheel bearing wear.
As long as the overall diameter is the same your powertrain won't know anything is different by running larger diameter rims... aside from them being lighter.
A quick junkyard run didn't net what I know I am looking for-a set of 4 good shoes. I found these in next to new condition. The rims though. I just don't know about the look. What do you guys think they will look on a truck? Anyone has a pic of a truck with these types of rims on it?
I know I can buy rims-50+ each and swap these tires into them, but only if I have, have, have to.
Most importantly, will the offset fit, will these fit right without causing any issues to gear/ball joints etc?
This is a 2007 Grand Marquis, 16" Rims
28094
Or this?
28095
i put 97 lincoln town car wheels on my 2001 truck. looks pretty decent.
28105
28106
i put the stock sized Ranger tires on the Lincoln 15" rims. No spacers or anything, just threw them on and thats it.
I came across this one....looks good.
On my Gen 1 V-8 Ranger I used 15 inch factory Crown Vic turbine wheels and center caps from about the same era... I color matched them to the truck and polished the ribs. Wish I had pictures... at the time... it looked pretty good... and I had a blast with it.
These are from my cousin's buddy's buddy explorer - 235/65R18 - that I am testing, not sure of the year but I just know it is a very new explorer.
Right off the bat what I would like to know is what are the risks associated with size 18's on a 1998 2.5 ranger? That is risks to transmission, differential, gear ratio, wheel steering system...or anything else? I am new to ranger, from camry so please educate me here.
Secondly, since I have been running them today this is what I have observed
A) - that steering lock to lock they rub top ball joint, and is it wishbone?? and the lower tie rod connecting rod???
B) - when I am driving and break hard the front wheels are whistling. This didn't happen with the previous 15's. What is this an indication of?
Other than that all four fit perfectly in the wheel well.
Lastly if there are no risks to damaging of the car and I keep them how would I make them work? Would adding spacers help with the rubbing? Must the truck be lifted? I would prefer not to get into lifting kits and all that at the moment due to budget constraints, not until the end of the year.
28416
