- Sep 9, 2009
- Chicagoland, IL USA
Understood on all!
One thing to consider: If you get the 8.8" 4:10 Torsen rear, you a.) might be able to sell the Torsen and b.) will get the 31 spline axles.
If you get a Ranger 8.8" with 4:10 that doesn't have the Torsen I don't think you get the 31 spline axles...fairly sure the only 31 spline Ranger was the FX4 models (as always, these are 'thinks' instead of 'knows').
You sure don't mess around on swapping sh1t out!
. I expressed my displeasure of making a 1.25 hour drive each way for nothing so we then talked deal on axles. They didn't have a 4.10 ranger front end to match the 4.10 fx4 posi rear they had, so we settled on a ranger 28 spline 8.8 3.73 for $170. I'm not concerned about the whole 28 vs 31 spline, I'm sure I'll spit a u joint before I break an axle shaft. Worst case, I'll sell this axle off down the road and get a 31 spline fx4 rear end and put some disks on it. My 7.5 was on it's last legs so this is a step up no matter what.
