B3000 TDI swap
i sort of mostly more then like it.....
thank you for the update.
Whitbread, any chance I could pick your brain for some details I can't work out? Or Greengeeker? We're swapping a BHW into an 04 currently.
reminds me of the lease roads out off of range lake road...
Got the boost up to 58psi now that the engine has some miles on it. I'm very happy overall with the fresh setup. The high pressure turbo is just a tiny bit lazier than I wanted below 2krpm, but we'll see if some further tune tweaks help at all with timing changes. Worst case, there's a 3mm smaller turbo in Garrett's catalog that's a direct replacement, just hurts the wallet.
Yeah, call or email me. Whitbreadperformance@gmail.com or 248 755 81oneeight.
Finally had a chance to put this on my friends chassis dyno. Did a couple runs and realized I was 10-15psi down on peak boost from the 75psi I previously had it set at. On the street its plenty zippy enough that basically never need to go full WOT so I didn't catch that boost was down. Assuming I have a small exhaust/boost leak of the internal gate on the little turbo isn't fully sealing.
Event Coverage
TRS Merch
