How do I lower my Ranger to a 'normal' height?
boblemans
10+ Year Member
Taylors, South Carolina
I just bought a really nice 2000 XLT with the towing package. I want to lower it to a more 'normal' height. It just sits too high and is bouncy. It has air shocks and extra leaf spring 'helpers'. It looks like if I remove the bracket that extends the rear leaf spring mounts, that might do some.
Can anyone tell me if that's the way or is there something else I can do?
I would appreciate any information, Thanks.
No offense, but it doesn't sound like you know what you are doing. If things are non stock, pictures if what you are working with would help a lot.
If you are talking about what I think, you do not want to remove them. Those would be shackles and they are a part of the factory suspension and are necessary for it to work properly. If you did remove them it would make the ride harsher.
4x4?
Removing the rear lift blocks will drop the back a good 2". Won't do much for the ride though.
I think they make drop spindles for that model year, not sure though. Most of those are good for 3". Again, won't do much for the ride though and the back would still be up in the air.
That's about it for easy lowering mods. Next step involves some cutting and re-arranging.
According to his info its a 2000 2wd with tow package. Sounds like he thinks its lifted, and he wants to lower it to a stock height.
Welcome to the forum boblemans,
As others have said send us some pictures of what you are talking about. Also you might want to swing over to a truck or suspension shop and ask them what they would recommend taking off.
If you find out what you want to do is possible I would put a ad on craigslist and see if someone wants what you have and make a deal where they pull it off in a labor/cash deal or something.
my experience with air shocks involved a lot of bounce, did not like them and pulled 'em off.
is your front suspension coil springs or torsion bars? from the factory there is about a 2" difference between the two systems.
Thank you all for the information. This was my first post on Ranger Station. Sorry for the lack of detail. I didn't know if anyone would even respond!
No offence taken, but I do know what I'm talking about. I have been working on my own cars for many, many years. Just never messed with leaf springs or anything on suspensions other than shocks, spring, ball joints.
I believe that the post regarding the air shocks was on point. I'm going to try that first.
I assume that the height is stock.
Thanks again!
You may know something about the parts of cars that you have worked on, but this:
What seems to be removing the shackle, suggests that you don't know.
And this:
Basically confirms that you don't know what you are looking at on this truck.
There is nothing wrong with not knowing, especially if you are willing to admit it and learn. I'm certainly not saying that you can't or shouldn't do the work your self. You've already started off the right way by asking questions first.
We can guess a lot at what you might, or might not, have based on your description. Quite frankly your description sucks, and we might be doing a lot of incorrect guessing and get you all screwed up. If you can post pictures (or links to them) of the suspension components that you are working with, it will help us to help you.
You may have helper springs, those won't usually affect ride unless the truck is loaded to a point where they are in use.
You may have add-a-leafs, or you might have explorer springs packs, or maybe they are the heaviest duty factory spring option. Add-a-leafs can definitely make the ride stiffer, that's why I don't like them as a lift option, but they are useful for more load capacity and some people love them.
You may have extended shackles, but from my personal experience they will not affect ride quality. I'd also be surprised if someone used extended shackles on a 2wd, but we'll know if we can see some pics. You definitely need shackles.
Air shocks can make for a bouncy ride if they are being run at too high of pressure. I had a set of Gabriel HiJackers on my 84 Ranger because the rear springs were worn out and needed a boost some times. As long as the pressure was minimum or set right for the load they didn't ride bad for a truck. That's not to say that you need them or that a set of standard shocks won't ride better.
Does it have lift blocks between the leaf springs and axle? If you have them and want to lower, they should be the first part to go. They can affect ride some and they have no benefit other than cheap lift, but honestly I just hate them.
Finally you say that you want to lower to a "normal" ride height. We've got no idea how it sits now, or what your idea of a normal ride height is. Pictures of what you've got will help us figure out where it is now. Then it's a matter of knowing how much lower you want it.
You also didn't mention what type of front suspension it has. There were two different suspension on the 2wd Rangers from 98+, coil springs or torsion bars. The style of front suspension will determine factory ride height, with the torsion bars sitting like a 4wd truck. Once again pictures will help us figure out what you've got and help you get where you want it to be.
Ya...I got it! I am just asking questions. I understand that I have asked some vague questions and picture would help a lot! I will post picture as soon as I can, then propose some additional question. I am very familiar with many car repairs, but this truck is only my third truck and the first one I have ever considered working on. It has no lift blocks and it does have front coil springs.
Thanks
Coil spring 2wd. Yep, it'll be interesting to see what the PO has done to it. With less than 5 posts you may not be able to post actual pictures, I can't remember what the minimum post requirement is for it. If it won't let you post them, post a link or send them to me in a PM and I'll post them for you as soon as I can.
Thanks
OK, I have a 2005 reg cab 2wd with front coil springs. should be the same setup as yours.
from the factory they ride a bit high. after all, they are trucks and are meant to drive over stuff. the front frame crossmember actually has more ground clearance than my 2000 4wd.
the easiest way to lower the front would be to cut a coil off each spring.
by the way, "towing package" means, among other things, bigger springs.
unless you are talking about the tow wiring harness, all recent Rangers came with that trailer plug.
