- Sep 5, 2015
I was gifted a 2000 Ranger XLT 2.5L with an undetermined clutch issue; the clutch loses its pressure after 30-45 minutes of being disengaged, it is parked with a stick to keep the pedal engaged to avoid this. Apparently before I owned it, the previous owner had taken the truck to two separate garages to get the clutch fixed which included bleeding the system, replacing slave and master cylinders and replacing hydraulic lines to the extent that the new replacement parts were replaced. The first garage pretty much said drive it off a cliff because they couldn't fix it and the determined/highly rated second garage did not have any more luck than them. From what I am told, replacing the cylinders and bleeding the system help for a couple weeks but the same problem would reoccur. I understand the system can have leaks, but if essentially everything was replaced, where do I even start?
